Electric Fan
Has anyone ever ran an electric fan setup on their OBS?Since I have added an intercooler to mine,when its hot outside and I am towing with the A/C on the clutch fan runs alot,which reduces pulling power.I would like to do away with the clutch fan and add an electric fan setup.Just wandering about the pros and cons.Thanks
There isn't a manufacture of electric fan that makes one for towing on a diesel. The ones that are made to replace the stock fan are not for pulling.
Your best bet would be to put one of the electric clutches on the stock fan. |
Well said.
Where is the best place to purchase one?
You'd have to scrounge around on ebay/craigslist/etc.
There were 2 versions: The Horton EC-450, which was intended for the T444E medium duty, but easily fits the 7.3. Part#996124 US Gear "cyclone power fan" kit. These were marketed for the SD 7.3, but can be made to work on a OBS. The US gear unit is no longer made, and has no tech support. The Horton is still available, but retail outlets have a hefty price of $650-1000. ![]() If you're patient, you can probably find a NOS one on ebay etc. for ~$300-350. I bought a Horton unit and it's in my OBS. Awesome unit. I have a couple US Gear units I've found, which I'll be putting on on the SD, and adapting the other to the Project OBS. |
I know a while back there was talk of adapting the 6.0 fan to the 7.3, I'd have to dig around for a thread but it seemed like a cost effective option as well.
You'd need to change the hub, since it is a LH thread on the 6.0 WP. The 6.0 uses a visctronic hub, which is a electronically controlled viscous hub. One would have to do some research as to required input voltage, etc. so it would work right.
We had a short discussion about this on another site I frequent. A Ford tech suggested using the 6.0 fan on the 7.3, when I asked him how hard it would be to do this was his reply:
What about A Linc. Conti. Fan? Its a dual setup, fits the radiator nicely and moves some air. I am more looking to free up some MPG while making more power. How much ECT does a PSD make? My temp guage struggles to make it into the "normal" area.
Wondering if anyone has found an electric fan that would work i don't tow often and getting rid of the mechanical fan has to give some power... my truck never reach the "N" on normal as it is so i think electric fans could be possible
