Vac pump failure
Pretty sure mine is dying a slow death- power brakes aren't working so hot and the AC blows out the defrost vents until RPM's come up. The pump is also making more noise and there is a buzzing under the dash that goes up/down with rpm.
Question- will a failing vac pump cause the e-brake light in the dash to come on? Since this problem started the e-brake light has been on also. At first it was intermittent, now it's on all the time. Last edited by superduty4x4; 06-06-2011 at 08:08 AM. |
vac pump in mine went out and made a wheezing sound when running, but they are pretty cheap to replace i paid maybe $80 or so at oreilly auto parts for mine
not sure about the light, but when mine went out the shaft broke, fan ate the belt, bit of a mess and left me stranded. like 351 i got a replacement for about $90 at oreilly's.
i wasnt moving but 15 mph or so, if i had been pulling a trailer the pucker factor would have skyrocketed! id replece it. rent the pulley tool if you dont have one. |
vac pump aint but 3 bolts i wanna say 7mm maybe, really easy i got one of those ratcheting box end wrenches made re install a hell of alot easier, my wife took my truck to work that day and mine ate the belt in the parking lot, so i put a new belt on it and it tore that to shreds in about 5 miles it took to get it home, they want a core charge too, and they swapped the pulley for me at the store
good point. tehy let me use their tool at the store, they were too busy to do it for me. iirc, when i had the problem, a few people stated that out vac pumps were poorly designed. snapping shafts, etc.
mine just stopped spinning, and would stick, spun a bit though if forced, but belt just ate up when it stuck and i got the good one that cost $90 with a 2 year warrenty, ate half way and snapped chewed it up good, guys at oreilly were like holy cow, that belt is guaranteed never to do that, so i got another one free
I swapped the pump from my wrecked truck last night, all is good in the neighborhood. The hardest part was getting the hose hooked back up! 3 10mm bolts, I used a box wrench and didn't have to fuss with the pulley at all.
i was close on the size, i used the cheap ratchet box wrench and it was glorious to get that thing, i wanna get a set of them here soon
Yes, the low vacuum will throw on the "brake" light. On the driver's fenderwell, there is the vacuum manifold and a small canister hooked to it. The small canister is the low vacuum warning switch.
get new if you can, ive had two napa rebuilt ones and the first lasted 3 months and im on the 2nd now.
