high idle control - Ford Powerstroke Diesel Forum
Old 06-03-2011, 05:12 PM
high idle control
does anyone have one of these factory high idle controls in there truck. bought this and put in, but will not work. powers up and the controller show the idle change on the controller, but truck does not idle up. not sure if it runs through the cruse or ebrake. any info would be great. would really like to get it working.
Old 06-03-2011, 05:35 PM
Full A-Team Member
E-brake activated, the light MUST be on in the dash for it to work.
Old 06-03-2011, 05:48 PM
thank you bud, my light does not come on. i though that it would of had something to do with ether the ebrake or cruse
Old 06-03-2011, 06:15 PM
Full A-Team Member
Wiggle the E-brake wire, i think its green, with the pedal depressed a lil bit. Thats what I have to do to get my light in the dash to come on
Old 06-03-2011, 06:54 PM
got my light to come on, the bulb was bad. controller still is not working
Old 06-03-2011, 06:58 PM
Full A-Team Member
Do you have the manual? Get it here...
https://www.fleet.ford.com/truckbbas...pcm_manual.pdf
Old 06-03-2011, 07:01 PM
no i don't. but thank you very much. going to check it out now to see what i can figure out
Old 06-03-2011, 07:49 PM
Side point, but it's a good thing you got that light fixed. The parking brake is only its secondary purpose. Its main purpose is to light up when your hydraulic brakes FAIL. That's NOT a light you want to drive around with it burned out.
Old 06-03-2011, 07:53 PM
right on bud, thank you. just realized it was out when i was figuring out this controller.
Old 06-04-2011, 11:38 AM
fordman thank you for your help. i got it to work. two bad bulbs is all it was. thank you again and have a good one
