KO wire under dash - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-31-2011, 05:37 AM Thread Starter
KO wire under dash
In your 94-98 PSD's - Is there a KO wire under the dash in a bundle labeled "Customer Access"? Or can anyone suggest a reliable KO source?
My buddy in Texas is installing a WVO kit in his '97 F350. I am in PA and trying to help out as best I can.
I have a customer access bundle in my 2000 7.3 under my dash with a light blue wire with a pink line down the side. When I installed my gauges the diesel manor instructions told me to use it because it is an easy KO source.
Any help would be greatly appreciated.
Thanks in advance.
2000 7.3L F350, SB, CC, Lariat, 4x4, 4" turbo back MBRP, WW, HPX, Leveling Kit, DP 9 Position, Foil Delete, ISSPRO gauges, DIY Intake, HD4R100, Hutch&Harpoon, GC Veggie Kit (heavily modified) + FPHE/VegthermMega/aluminum HIH/CoPilot.
[SIGPIC][/SIGPIC]
BArakus is offline
post #2 of 2 Old 05-31-2011, 06:49 AM
superduty4x4's Avatar
There isn't a customer access bundle on the OBS like the SD has unfortunately. When I needed KO power for my gauges in my 96 I tapped into one of the wires on the backside of the fuse panel in the cab. You might be able to grab something under the hood at that fuse box as well. There is always the fuse tap option as well.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
