HELP ASAP PLEASE.. Sparked the battery now no start - Ford Powerstroke Diesel Forum
Old 05-22-2011, 02:19 PM
I have a big trip coming up in days... so I'm stressing..
Van E-350
7.3 Diesel
1997
Battery's are showing 12.9 vlts
I was taking the positive line off the second / Aux battery that runs in parallels with the main battery (stock set up)... I forgot to pull the ground and I hit the wrench on the frame and a good spark happened... and I believe this is why I no longer can't start the van... any thoughts?
1st time starting after this happen...
everything sounded fine... very slow crank for 1 second then stopped...
2nd time starting after this happen..
I put the key into the ignition and everything seems find... and then I turned the key into glow plug mode.... nothing... I tried to turn it over and all I got was an odd week door bell chine and nothing.. If I step on the breaks... the doorbell chime stops.... odd
I disconnected the batteries let it sit for a minute then tried again and the same as the second attempt.
The Battery connectors are good...
What am I in for... is this bad... or fatal?
Could it be the started relay....
I checked all the fuses in the engine compartment too and all is good there.
Please help I'm in a very critical period for a big trip.
Old 05-22-2011, 02:21 PM
Chapter Director
u prob def burned something id say relay or check ur fuse panel just hope its not the ecu
Old 05-22-2011, 02:27 PM
I would check all your fuses
Old 05-22-2011, 02:51 PM
the "wait to start light" doesn't come on
why do you hope it's not the EIC?... Price.. Other concerns?
Old 05-22-2011, 02:56 PM
Chapter Director
i have heard of people frying the computer but im not to sure if something like that could
Old 05-22-2011, 03:07 PM
Shade tree mechanic
If you have no wait to start light, then the PCM is not getting power to it.
Old 05-22-2011, 03:17 PM
does that mean ... a fuse is likely blown or the starter relay is dead...
or is the ECM fried
Old 05-22-2011, 03:22 PM
Shade tree mechanic
I know you said you checked the fuses, but did you check the fuses that are under the hood? Pay extra special attention to fuse #22
Old 05-22-2011, 04:40 PM
My Van has the ambulance altenator for extra power, but not the package.. Ok... so I found a 25 amp fuse blown inside the cab... in position 28... i do not have a diagram so I'm not sure what position 28 fuse is for...I replaced it and nothing changed..... I looked at the inline fuse by the starter relay.. it looks like two yellow ... lines... it doesn't look like a fuse nor can I tell if it has been blown...
again the "wait to start" doesn't come on....
Old 05-22-2011, 07:28 PM
I checked the fuse under the hood an in the cab.
thanks
Jeff
