dana 60 swap problem - Ford Powerstroke Diesel Forum
Old 05-17-2011, 03:06 PM
ok so swapping in my dana 60 into my 95 f-250 i realized i had a 1992 dana 60.problem is my 95 has bolt on calipers the 92 has the triangle pin type calipers.is there anyway around this or am i going to have to buy new calipers? also if i do have to buy new calipers will my factory brake lines work or do i have to buy those to? thanks in advance
Old 05-17-2011, 04:45 PM
Your 92 Dana 60 has the king pin style knuckle. You will need to get the calipers for that axle. Your brake lines will work with a little light grinding around the ends where the banjo bolt goes thru.
Old 05-17-2011, 08:46 PM
the 92 flex brake line will bolt into the 95 hardlnes and then u can bolt the flex line to the caliper. Ur looking at about $150 in parts caliper, hoses, and pads. Good luck i just did this to my truck about 3 weeks ago it works great.
