96 7.3 not running - Ford Powerstroke Diesel Forum
post #1 of 70 Old 05-16-2011, 09:46 AM Thread Starter
96 7.3 not running
I have a 96 450. Truck ran fine. Parked and would not start. 140k on miles. Computer check shows everything passed. Changed cam sensor. no change. Will crank but no start. Glows plugs fine. Can hold a rag soaked with fuel in front of air intake. Truck fire right up until fumes burned off. low oil pressure at 25lbs.
Any thoughts?
jrh37 is offline
post #2 of 70 Old 05-16-2011, 09:57 AM
sgt dave's Avatar
Quoted: 3 Post(s)
Probably your fuel pump
1996 F250 SC/LB, 4x4 PSD, ATS stage 1 trans 5 star tcc, AC codes,TW tunes, magnaflow 4" exhaust, 6637 , FS 2500 bypass oil filter,pure power reusable oil filter, isspro gauges, dieselsite cpr fuel pump system, adrenaline hpop, pml rear diff cover ,ebpv delete,non epbv pedestal, king pin dana 60, swamps idm, tru cool 4739
USMC 1993-1998
Plumbers & Pipefitters L.U.447
sgt dave is offline
post #3 of 70 Old 05-16-2011, 10:27 AM
ridiculously_necessary's Avatar
x2 fuel pump. also load test your batteries. (pull cables for this) if you have one bad battery it can screw with your head.
things to check, injector harness, ipr and ipc connections, etc. without the rag in front of the filter do you get any smoke? i assume you check the fuel filter?
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #4 of 70 Old 05-17-2011, 12:11 PM Thread Starter
Thanks guys.Just put the pump on. Guess the turbo guys didnt talk to the fuel guys about the banjo bolt. Fuel filter is new. Truck the same. Batteries new but shop wore them down. recharging now. Guess next step is ipr or pull valve covers.
jrh37 is offline
post #5 of 70 Old 05-17-2011, 06:18 PM
I've got a '96 F350 with a similar issue, only mine won't fill the fuel bowl. I've only got a little above 1/4 tank of fuel, thinking my pickup tube might have come off in the tank or something. I can hear some sucking sounds when cranking. Will put a few more gallons in it and see what happens. Will let you know what it turns out to be.
blef70 is offline
post #6 of 70 Old 05-18-2011, 05:50 AM
know anyone with autoenginuity?
you can hear a sucking noise over cranking? do you have an electric conversion?
-Matt
DIY 6637
Marinco Mod
post #7 of 70 Old 05-18-2011, 12:46 PM
Nah, I was kneeling by the side of the vehicle while the wife cranking it, when she stopped I could here some gurgling in the tank. By the way, sorry to hear about your truck being totalled, hope you get it replaced with another PSD soon! I've only had mine a couple weeks and love it. Would love it even more if it would start - Blaine
blef70 is offline
post #8 of 70 Old 05-18-2011, 01:12 PM
maybe the fuel is leaking back into the tank? have anylines with cracks or air seepage?
thanks, im looking now, insurance came through and im stalking a few different trucks.
-Matt
DIY 6637
Marinco Mod
post #9 of 70 Old 05-18-2011, 02:39 PM
Not sure, but haven't seen any leaks. It just seems wierd that it would be running fine, then after sitting for a week not want to start. Will be adding more fuel in the tank tonight to see if that helps. By the way, here's one in NM where I am that looks like a decent deal, not sure where you're at but if you're close might be worth the drive - http://albuquerque.craigslist.org/cto/2385113277.html
blef70 is offline
post #10 of 70 Old 05-18-2011, 03:23 PM
RPurdy's Avatar
Check timing. i know it seems silly but I had this problem once. I went nuts chaning all kind of stuffs and the timing was bad.
F350 Ex Cab, Dually, E40D, 167K, 4x4, Banks Turbo, 4'' SP, 4.10s, 30+ Running Lights
Looking for-
Set of Dually Alcolas
Blue or Grey Bucket Seats
Originally Posted by JMart View Post
Oddest thing I have ever seen but very original. Its kinda like a super duty raped a sporttrac and had a b@stard son.
RPurdy is offline
