f250 ttb to d60 - Ford Powerstroke Diesel Forum
Old 05-14-2011, 02:41 PM
f250 ttb to d60
what all is needed to do the swap> thanks
Old 05-14-2011, 03:15 PM
Axle
Steering linkage
Track bar
Get everything you can if you are stripping a donor truck. It is an easy bolt on swap. I did it last year.
Old 05-16-2011, 01:01 PM
Feedback Score: 5 reviews
If your looking at the best ride quality then you want our RS kit-V and B mod ..PM me if I can help
Old 06-02-2011, 05:05 AM
if you are still doing the swap I have a steering linkage,trac bar and bracket.You will have to drill a few holes on the engine crossmember but other than that its a bolt in deal,last one I did took about 4 hours....well worth the effort
Old 06-02-2011, 10:59 AM
If you can pull the TTB and install the D60 in 4 hours your hired!
Old 06-02-2011, 11:09 AM
About what it took me Cary, including setting the toe. But I didn't swap the leafs initially, and I'm a professional mechanic.
Old 06-02-2011, 11:50 AM
do you have to swap the leafs? and what would you gain by doing so if you did use 350 leafs? and is there a difference between the 92-97 d60 and 99-04 d60? i know 05 and up is coil sprung but wuts the difference in swapping those 2?
Old 06-02-2011, 12:09 PM
Ah.. that explanes it..takes me a day but I will only do this if adding a RS kit SD spring swap.
Gain by using SD springs..saves your kidneys..
We have kits for 99-10's
99-'04's Big 4 wheel disk brakes..
Old 06-02-2011, 12:13 PM
wuts RS? and sd springs for a d60 swap on an obs leaf?
Old 06-02-2011, 12:24 PM
RS kit..reverse shackle kit..needed to use either SD springs or 99-04 axles. We developed this mod..PM me for additional info on these or '05 up axle swaps into a OBS or 99-04 SD.
Cary
