Turbo housing newer 7.3 to a OBS - Ford Powerstroke Diesel Forum
post #1 of 9 Old 05-14-2011, 02:05 PM Thread Starter
farmallcrew's Avatar
have any of you guys put on a turbo houseing from a newer 7.3 on a 1997 or OBS truck, will it fit around the turbo? Im putting a intercooler in my 97 F250 and my diesel guy said he forgets if the newer 7.3 turbo housings can bolt on to the older ones. I want to use the bigger diameter piping for the spyder and intakes thats why we were wondering if the turbo houseing swap can happen.
1997 F-250 Crew Cab 7.3 4x4 (truck built 12-97)
2 - 8" Mitre cuts
Bully Dog 6 pos chip
Dfuser 18K module
FPR shimmed
RECON Smoke AMBER roof lights
Fire and Ice lightbar under tailgate
ITP Overboost Annihilator
Not running fire company at the moment but still on the truck
2 - 5 ft. FireStik Antenna's hooked into BC 350c Scanner
Vector 7 pod
Soon to be on truck:
Intercooler, new HPOP, straight axle, New OBS starter
farmallcrew is offline
post #2 of 9 Old 05-16-2011, 07:33 AM
superduty4x4's Avatar
No the SD compressor housing will not fit your truck.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #3 of 9 Old 05-18-2011, 04:48 AM Thread Starter
ok anymore insite?
2 - 8" Mitre cuts
Dfuser 18K module
FPR shimmed
Vector 7 pod
post #4 of 9 Old 05-18-2011, 11:34 AM
olblue97's Avatar
the super duty housing will not fit the truck but you can make the newer turbo fit the obs alot of people do this so that instead of running the D66 they can do the Gtp38R conversion
check link and here is a list of the parts needed real easy swap getting my manifolds this friday and i will have the complete swap kit
3" plenums (OBS had 2")
SD manifolds
SD up-pipes
SD turbo pedistal
SD intake Y (the start of your IC system)
All the hardware required to install this
Basically it turns your OBS in a SD on the airflow side of things. Lots of guys do it so they can run a 38r instead of the D66.
http://www.powerstroke.org/forum/per...onversion.html
1994 F350 4x4 CCLBDRW
HID kit
front and rear captains chairs
full stereo flip out DVD
1995 cummins 12 valve (shhhh)
future mods
40 inch flush grill mounted LED lightbar
king ranch interior
front and rear HD bumpers
bronco fuel tank
olblue97 is offline
post #5 of 9 Old 05-25-2011, 06:27 AM Thread Starter
anybody have those extra SD parts laying around, or know where i can get them cheap? alot of the junkyards around here wont take that stuff off motors, you have to buy the whole motor. so im looking to do this project cheaper than a motor.
2 - 8" Mitre cuts
Dfuser 18K module
FPR shimmed
Vector 7 pod
post #6 of 9 Old 05-25-2011, 07:46 AM
Why not just find an E99 intake spyder for $150-200? Or build your own using the stock y-pipe? That will be way cheaper and easier than doing an SD conversion.
post #7 of 9 Old 05-25-2011, 12:22 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
if you just swap out the spyder would an E-99 intercooler work?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #8 of 9 Old 05-25-2011, 12:38 PM
Any intercooler will work. The E99 intake spyder is the only one that will work with a stock turbo, unless you build one yourself using the stock Y pipe.
post #9 of 9 Old 05-25-2011, 01:59 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
how hard would it be to get the compound turbo off a newer model and put that in?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
