replacing injecters
well im gonna be replacing my injecters within the next week with bdp
stage 1's, and i was just wondering if you guys had any tips that would make it easier, and i was also wondering if i could run a custom tuned chip on a stock lift pump just until i get the money to do an electric fuel. thanks |
Stage 1's will run fine with the stock pump just clean the screen and do the BB mod.
1 at a time starting with the back..suck out the oil then take out the next Inj..etc then resuck all over again then put in the new Inj's. You should be looking at a HPOP..17* or best..SRP1 IC Will be needed along with guages. |
Perhaps this will help out a little....
OBS Injector R&R |
while ur there do the glow plugs also.
to clear oil from cylinders: -installed the injetors -removed the glowplug -reinstalled the valve covers with a few bolts. -with the wiring harnes un pluged cranked the motor for 30 seconds. -This will clear all the oil from the cylinders. I also used shop rags to soke up oil as i pulled injectors. Also alfter you have torqued all the injectors to spec u should place a straight edge across the top of them make sure they are all level. If not it means they are not seated all the way and/or one of the old brass washers got left in the injector cup. CTPerformance told me this trick. Assembly lube. Also I am running stage1s with manuel lift pump and 15*hpop. I never had a problem with EGTs unless towing daily driving was fine. Of course i did not run a tunner. Last edited by tracker8wr; 05-11-2011 at 12:26 PM. |
whats a bb mod, and whats the cheapest way to put an ic in my truck?
i already have gauges, how hot is too hot for egts?
IC can be done by buying an e99 spyder,IC, and fabricating sd pipes to fit. Where do you have your egt probe installed at? |
im sorry but what does bb stand for and fpr? and its at the end of the drivers header before it goes up towards the turbo.
alright thanks, and where could i find an e99 spyder?
