fpr screen location
Can't remember its location. Is it inside fuel bowl? Any pics showing where? Thx in advance
The FPR is on the outside front drivers side of the fuel bowl. 2 bolts and it's off the bowl. You'll see the screen once the FPR is removed from the bowl. Don't overtighten when re-installing.
Do I have to drain the fuel bowl before i undo the bolts?
You can access the screen from inside the bowl if you want. It's about 1/4 of the way down on the driver's side. Pull the cotton off a Q-tip and use the stick to scrape the crud off the screen.
