Need help with noise - Ford Powerstroke Diesel Forum
post #1 of 18 Old 05-07-2011, 01:52 PM Thread Starter
i just put a smf and a 3.5" downpipe in at the same time and when im in 1st or 2cnd gear idling or at lower rpm's i can hear a grinding or rubbing type noise. ive pushed the firewall back with a portapower, i have about an 1" of clearnce. has anyone expeirenced this before? do i need more dp clearnce?
95 f250 is offline
post #2 of 18 Old 05-07-2011, 02:57 PM
yes, its for sure your exhaust, you may also look where the down pipe goes by your tranny lines and make sure its not rubbing
2004 cclb 07 conversion, 07 intake mainfold, s&b intake, 4inch turbo back 5 inch tip with flowmaster
, cfm large mouth, larger ic tube, high idle mod, egr delete, studs, ats 5 star tq, sct with customs tunes by innovation diesel.
exterior- nitto terra grapplers, v-tech wheels, 07 harely lights, 07 studded grill, 07 bumper, 05 f350 emblems.
LOOKING FOR 08 MIRRORS ALL POWER CHEAP
LOOKING FOR CHEAP 05 07 DASH ALSO
next up is banks techni cooler and itp fuel return.
banks2293 is offline
post #3 of 18 Old 05-07-2011, 03:43 PM Thread Starter
The only place that it was close to anything other than the firewall was the trans crossmember and I checked that and it was not the source. How much clearance do i need for this dp?
95 f250 is offline
post #4 of 18 Old 05-07-2011, 03:51 PM
If u r sure the nose is from Ur exhaust. U can always rap it in heat rap. If it is clanking on things that will or proved a barrier. exhaust heat rap.
tracker8wr is offline
post #5 of 18 Old 05-07-2011, 04:59 PM Thread Starter
I don't know if its the dp for sure yet. I've heard about trucks having gear noise after a smf conversion, but I don't think this noise is that because of when it does it? What amount of clearance does an average dp take to not rub atall? In inches
95 f250 is offline
post #6 of 18 Old 05-07-2011, 05:58 PM
Quoted: 53 Post(s)
Could still be the gear noise introduced by the single mass. We have one in the RCLB, and come to think of it, you don't hear it so much at higher speeds, probably just because its masked by the increased road noise.
madpogue is offline
post #7 of 18 Old 05-07-2011, 06:13 PM Thread Starter
madpogue Is that gear noise none stop at lower speeds ?
95 f250 is offline
post #8 of 18 Old 05-07-2011, 06:30 PM
Quoted: 53 Post(s)
No, seems like you hear it right on launch.
madpogue is offline
post #9 of 18 Old 05-07-2011, 07:09 PM
troykimber's Avatar
i have a solid flywheel and it is noisy. espescially at low rpm's and when the motor is bogging. it goes away when she spools up a little
if it was the downpipe, u would hear it all the time.
95 sc lb 4x4 5 speed
ts 6 position chip, boost relief valve, 4" intake, 3" downpipe-5" rest of the way to a stack, fpr shim, twin 16" s-blade electric fans, poly bushings, zoom variable torque ceramic clutch with solid flywheel, hydroboost, stancor relay, exhaust brake, ss hpx line, 140v idm, bar and plate intercooler, glowshift gauges, gt grant signature series wheel with black billet hub, rockford door speakers- pioneer head unit- 2x 12" kenwood w3 subs
troykimber is offline
post #10 of 18 Old 05-08-2011, 04:27 AM Thread Starter
madpogue troykimber can you describe the gear noise that you have ?
95 f250 is offline
