strange humming at 65 mph - Ford Powerstroke Diesel Forum
post #1 of 7 Old 05-02-2011, 02:30 PM Thread Starter
Just fiished my axle swap and I have a strange loud humming from 63 to 66 mph. If i depress the clutch it stops. As soon as i go over 66 mph it stops. Any thoughts all bearing in front and rear just rebuilt. this started after i swaped in the rear but its not coming from the rear. sounds like front drivers side. Just had the alignment done rotated tires and filled to proper PSI. I am guessing i need to check trans and tcase. Also checked lock out hubs they r working properly.
tracker8wr is offline
post #2 of 7 Old 05-02-2011, 05:24 PM Thread Starter
I have a zf5 in my truck under normal operation what temp should it get up to. Should the case get hot. Its not to hot to touch but i can't leave my hand there for long.
post #3 of 7 Old 05-03-2011, 08:16 PM
is the humming a high pitched vibration? If so check drive drive shafts, if its a low warble check tires and rims.
1995 F250 Single Cab.
D60 Swap and Super Duty springs.
315/75/16 Tires.
Custom Light Bar for night missions.
BrianH is offline
post #4 of 7 Old 05-03-2011, 08:38 PM Thread Starter
Sounds like a tire out of balance but i rotated them and balanced them. Still doing it.
post #5 of 7 Old 05-03-2011, 08:39 PM
350ninty7's Avatar
I agree you should look at the U Joints / shafts since the sound goes away when you depress the clutch. Under a load ( clutch engaged ) it could be a bearing in transmission or transfer case. How many miles on the ZF 5 spd.
2012 F350 XLT 6.7 CC LWB SRW
11,500 GVW FX4 Off Road, Camper, & Prem XLT Options
2012 Montana Mountaineer 326 5th Wheel
SOLD and Missed
1997 F350 XLT 7.3 Liter Power Stroke
Reg Cab 4X4 Off Road Pkge
5 spd Manual with South Bend Clutch Upgrade
AFE Stage 2
Diamond Eye 3" Down Pipe 4" Exhaust Cat Delete
TW Tunes
WARN Winch
Original Owner 179,000 Miles
350ninty7 is offline
post #6 of 7 Old 05-03-2011, 08:54 PM Thread Starter
It has 241k on it now. I know it reaching end life. I just found a zf5 out of a 93 diesel for $100 going to pick it up tomarrow had 110k on it but i am hoping a ujoint. Im going to put fresh flude Royal Purple synthetic ATF in the tcase and tranny tomarrow. I am still driving waiting for it to let lose so then i will know what to fix.
post #7 of 7 Old 05-04-2011, 08:57 PM
350ninty7's Avatar
Just my .02, You don't want to be traveling 65 miles per hour and have a U-joint come unraveled as that can get real nasty and costly under there. U Joints aren't that expensive and if in doubt change them out. I got 165,000 out of mine and though they weren't making noise they were loose. 100 bucks for a ZF5 with that mileage is a good price. Throw another $400 bucks at the project and toss in a new South Bend or Valair Clutch especially if you are still running the factory Dual Mass.
SOLD and Missed
AFE Stage 2
TW Tunes
WARN Winch
