Leak
I walked out and found a small puddle of anitfreeze under the front of the truck. I believe I found the culprit but I have no idea what its for. I know I have a big main radiator and then the little black box on the behind the grill is the tranny cooler. The radiator looking thing in between them is leaking. Its a very slow leak. But if anyone can give me any ideas on what that radiator is for or how to fix it.
It's called a condensor, it's for your a/c
thanks for your help. I couldnt figure out what it was for. I drove it around but nothing overheated. so I take its nothing to worry about for now? also it looks like antifreeze but is it antifreeze or another fluid?
Water pump has a weep hole on top, when it starts to leak fluid it's time for a new water pump. Keep an eye on it and watch your surge tank to see if it's getting low
well nothing is wet around the water pump. and the leak is right underneath the front bumper. what is the surge tank? do you mean the reservoir?
i found the leak its at the bottom of the condensor. I also researched that the a/c has a green dye in it. does the condenser have coolant in it or is it full of the a/c system fluids. Ive been watching my reservoir and the coolant level is not moving.
a/c system has refrigerant oil in it and it's clear. Turn your a/c on and does it get cold?
not sure. I rarely use the a/c.
anyone else have any ideas? the green stuff felt oily and is like a bright neon green
Thats the dye in the freon. Probably took a hit from a rock in the condenser.
