drivers side back brake drum hot as hell
Had a buddy adjust back brakes out on Monday evening. Today got home from work smelled burnt brakes on drivers side. Touched the drum it was hot as hell! The other side was fine no smell no heat. Is this normal? He said he adjusted them so they drag just a little bit. Any thoughts... hints...
Park brake on? Shouldn't smell at all. I'd pull the drum to see what's going on.
that is not right. the brake was stuck on. you need to take it back apart and see why it is sticking
sounds like the parking brake was on,
Got r done! The shoes were out way too far had a hell of a time getting the drum off. Just eased them back some. Should be good to go now. Thx fellas
Alot of the time the parking brake cables go bad a stick on but good to hear you fixed it!
Took it for a spin... world of difference! Should've known the brake pedal was tight as hell. Pedal feels normal again. Have a good Easter everyone.
