76 F250 diesel swap, which motor to use? - Ford Powerstroke Diesel Forum
post #1 of 76 Old 04-21-2011, 08:46 PM Thread Starter
Wilson7397's Avatar
I have a 1976 F250 Highboy , with a 78 cab and front clip, with no motor, np435 trans and divorced np205, Light Dana 60 front. (the rare one with ball joints and disc brakes) and 60 rear.
The truck originally had a 360 in it, I've thought about rebuilding a 460 i have for it but for the same money i could probably just buy a diesel, and get twice the fuel miledge.
Im stuck between just buying a 12 valve cummins and 2wd NV4500 and buying the $800 mount/cross member from auto world in montana, buying the motor mounts from destroked for $400 or just custom building motor mounts.
Or just cutting the crossmember out of 80-97 ford truck and welding it in between my frame rails and using a 7.3 IDI with an aftermarket turbo kit or a 7.3 Powerstroke and having a wiring nightmare to deal with, and using a 2wd zf5 or zf6.
I just wanted to see if anyone out there had any insight into such a project or has done it before, or has any other Ideas that could be more practical.
thanks,
Scott
Wilson7397 is offline
post #2 of 76 Old 04-21-2011, 09:02 PM
Buffalo444's Avatar
depends on how much you have to drop in it... already seen a 7.3 powerstroke in a late 70's model, probably been done with a 12v too, and I know its been done with a 4bt... looks like you got a bit of body work too...
If it were me, I'd knock the body out, then decide what motor. $$$ allowing, I'd think outside of the box... like maybe a DT360, DT466, or maybe some small mechanical diesel fuel sipper... but i'd probably keep it mechanical too, if trying to stay on a deadline of sorts. If not, go all out. Hell, buy a crate 6.7 powerstroke, REALLY turn heads! and no emmisions in the 70's
Jason
First rig: e99 F250 CCSB 4x4 auto, white, 388k miles: traded in
Then: 02 F350 RCLB SRW 4x4 zf6, silver, 201k miles, THREW A ROD
: traded to Jake
Now: 96 F350 CCLB DRW 4x2 auto, red and silver/grey, 266k miles: rusty but trusty
Buffalo444 is offline
post #3 of 76 Old 04-22-2011, 03:54 AM
Mutley's Avatar
I wonder how much a crate engine is (never looked)? I'd be liking the cummins swap in there with a flat black paint job. Ya baby! Git er dirty & don't worry about the look so much. Just curious, is there a thread here about doing a cummins swap into an obs with pics?
94.5 PSD Dually Crewcab F-350. Uglee, stock and reliable.
Mutley is offline
post #4 of 76 Old 04-22-2011, 05:17 AM
Buffalo444's Avatar
For a crate 6.7? like 19k lol. ANd by OBS do you mean your BS? Because I dont think so on here, you might try the nation. There is one on here for a 4bt into a late 70's model crew cab that is SAWEET!
Jason
: traded to Jake
post #5 of 76 Old 04-22-2011, 09:39 AM
rolsmojave3's Avatar
I've always wanted a 77 with a turbo'd 6.9l
1997 Ford F-350 4x4 SRW regular cab manual trans.
-4.10s, 315/75r16...getting a frame off restoration. Go fast stuff
1996 Ford F-350 4x4 SRW CCLB manual trans. CALI spec
-ATS intercooler, WW2 w/ 1.0 housing/EPBV delete, Comp 910s, SD Efuel, 3.55s, 315/75r16
2002 Ranger FX4 with manual transfer case and Alcoa's
rolsmojave3 is offline
post #6 of 76 Old 04-22-2011, 09:55 AM
justinlogue5_0's Avatar
I know you can get the new 600 HP Coyote gasser motor with all the harness,computer etc... from ford for about 15 to 20K and its get in the high 20's on mpg.
A little bit of this and a little bit of that. I want a lot more of this and a lot more of that
It never ends!
justinlogue5_0 is offline
post #7 of 76 Old 04-22-2011, 10:06 AM
Nashotah7's Avatar
Well if you go with a 7.3, well for that matter, any motor, there is a company out there that will build you a wiring harness for whatever you want to put in there. They just need the motor choice, the year/make of the vehicle, and what kind of acessories you are going to run. They utilize as much of the factory instruments and dash lights/switches as possible. Now I don't know the name or where they are located, I just happened to see it on the t.v. show "Trucks" on the Spike channel. I never tried to look them up figuring I would when I go to swapping the 7.3 I have into a '91 F250 4x4. But if I had your high boy I would deffinetly go with the built 460 and pound the **** out of the trails. You ever think about selling it???
Nashotah7 is offline
post #8 of 76 Old 04-22-2011, 10:59 AM
Gruss's Avatar
Hate to say it, but put a Cummins in it.
"If you want smoke, work for it. These guys did" JJFLASH
Stormtrooper:: 1997 F-350 CC SRW PSD XLT 4X4: Baby Swamps, Wildman 4 pos chip, 120V IDM, SD Intercooler,BTS E4OD, RSK, CCV mod, shimmed FPR, DIY 6637 air filter, triple pillar pod with Isspro gauges, 4" MBRP exhaust, SD dual tensioner,
Gruss is offline
post #9 of 76 Old 04-22-2011, 11:20 AM
strokin95style's Avatar
Id say go with the dt466 or the 7.3, dont get me wrong the cummins is a good engine, but they are everywhere and in everything. dare to be different. besides the zf6 is a better transmission than the NV. as for wiring, i believe the company that Nashotah7 is talking about is called painless. Painless Performance: The Official Home Page For The Best In Automotive and Diesel Performance Products
Nater
1995 f-250 rclb
7.3~317k miles & countin
3" Downpipe
Superduty 10.5" 3 pinion Trac-Lok rear
Dana 60 s.a.s
1997 ccsb , 353,500 miles
5" lift on 315x75x16 cooper at3's.
Clear headlights, tinted tails, rear buckets,
Dana 60 swap, zf5 swap.
rosewood 180/100's, t500 hpop, php hydra, e fuel.
strokin95style is offline
post #10 of 76 Old 04-22-2011, 02:26 PM Thread Starter
Wilson7397's Avatar
The body isn't quite as bad as it looks, the hood is about rotted threw but i have i perfect hood that came on a front clip i bought at an auction for $8.00, but the fenders and core support are good, It needs one cab corner, the floors are good and i need to patch a little hole or two at the bottom back window. I have a perfect 40/20/40 console seats out of an 01 dodge ram, The bed floor is decent, the wheel wells are good, but on both sides behind the rear wheels there are rust holes, and the driver side has bondo around the hole for the filler neck. The brake lines look fine.
I know the proper procedure is to do all the bodywork first, and then the mechanical side. But, i feel like if i have a motor in it, and it'll start and move, it will give me alot more motivation to do all the bodywork. Im aiming in the direction of a good running diesel that i can afford to drive, that i can take 4 wheeling and pull my trailer with, the paint and body aren't a top priority, i kind of like the miss matched paint scheme, or maybe do one of the "patina"made to look old paint jobs.
The picture of it is from last spring, since then I've power washed it, put it in my garage, fabricated a headache rack out of an old cattle gate, and filled the bed up with exhaust and plenty of other junk.
I've looked into dt414, dt466 and detroits, The DT series are really large engines, diesel power mag. had a readers rides picture of an 80's C30 with a 11 dump bed that had a DT466, the owner said he had to stretch the engine compartment 4 inches and spend 2000 hours on it. There are a couple youtube videos of old chevys and fords with 4v53's and there is a 79 f250 tow truck with a 6v53 which looked like a severly tight fit and i think they weigh 1800 pounds,
