96' shuts off on right turns??????????? - Ford Powerstroke Diesel Forum
Old 04-19-2011, 01:39 PM
Before I start tearing into the wiring, I thought would check here first. My truck shuts off on right turns. This happens only when driving. If I'm not moving I can turn right all day ( i just don't get anywhere ). Its gotta be a wire or the computer, right? Has anyone had this problem? I still have power ( electric d2 pump still runs ), I have to turn off the ignition before it will start again. Thanks for your help.
David
I am posting this in different places, sorry if you read it more than once.
Old 04-19-2011, 04:17 PM
Here is the update. Its either the idm or pcm. After checking out all the under counsel wires, I popped the hood and started with the Idm. after a little time with a hammer, I found that there must be a short between the idm and pcm. The truck runs fine, now I just need to find the problem.
