HiSteer D60 Tie Rod ??? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-16-2011, 09:51 PM Thread Starter
Climbit's Avatar
I have been spending alot of time researching a new tie rod setup for my ball joint dana 60 swap into my 95 F250.
I am coming up empty... I would like to run a 1 1/4 DOM threaded tube in place of the OEM rod, but cant seem to find tie rod ends that are spec'd to fit the ball joint axle setup. Does anyone know if the Chevy rod ends will fit these front ends, from my research it looks like the Chevy ends will fit the king pin style but I cant find anywhere that sell rod ends to fit a ball joint style axle.
Thought about using Heim Joints but then I would have to drill my knuckles to accomodate the standard bolt to fasten them.
What is everyone using out there ????
1995 S/C F-250
Dana 60
Icon Springs
Reverse Shackle
Bilsteins
2008 Toyota FJ Trail teams White
Climbit is offline
post #2 of 5 Old 04-17-2011, 08:02 AM
sgt dave's Avatar
Quoted: 3 Post(s)
I think sky mfg has what you are looking for. They make the rsk for these trucks
1996 F250 SC/LB, 4x4 PSD, ATS stage 1 trans 5 star tcc, AC codes,TW tunes, magnaflow 4" exhaust, 6637 , FS 2500 bypass oil filter,pure power reusable oil filter, isspro gauges, dieselsite cpr fuel pump system, adrenaline hpop, pml rear diff cover ,ebpv delete,non epbv pedestal, king pin dana 60, swamps idm, tru cool 4739
USMC 1993-1998
Plumbers & Pipefitters L.U.447
sgt dave is online now
post #3 of 5 Old 04-17-2011, 09:53 AM Thread Starter
Climbit's Avatar
I emailed Sky and they dont have anything that will work
1995 S/C F-250
Dana 60
Icon Springs
Reverse Shackle
Bilsteins
Climbit is offline
post #4 of 5 Old 04-18-2011, 09:10 PM
Electrical Ogre
alberta 7.3's Avatar
Quoted: 114 Post(s)
Ford Dana 60 Ball Joint Crossover Steering Convers - Sky's Off-road Design
Why do they show it then?
Also check out this guy, he's doing the SDs, he probably has or can do a OBS setup
Dana 60 unit/ball joint steer arms/kit - Pirate4x4.Com Bulletin Board
Bill
1996 F250 SC/SB 4X4 XLT
1997 F250 RC/SB 2WD project
2008 F350 CC/LB 4X4 DRW Lariat, 3" cow catcher mod
2008 Ranger SC FX4
Originally Posted by weareweird69 View Post
If your posting pictures bill, everyone dim their screens, that CAT YELLOW is bright
Originally Posted by Fordman247365 View Post
Is there anything you DONT take apart and **** with?
Originally Posted by JJFLASH View Post
I still say that those Dodge mirrors have as much business on a OBS Ford as yoga pants have on a fat chick...my .02
alberta 7.3 is offline
post #5 of 5 Old 04-26-2011, 11:51 AM
nic0084's Avatar
I dont know if you have solved your problem yet, but... GM TRE's would be the way to go. You can find 7/8 18tpi threaded tubing inserts at various websites. You can also build your drag link with opposite threaded TRE's on either side, making it easily adjustable. You can either ream out the locations you need to fit the TRE or you can get inserts. You drill a 1" hole and install the insert that accepts the GM TRE.
97 F350 7.3 Off-Road Build Locked on 42's
08 2500 Cummins
nic0084 is offline
