Tire air pressure......what should I run with 265/75-16 tires? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 04-14-2011, 03:02 AM Thread Starter
mikenj's Avatar
Didn't know these trucks run so much air in the tires! What psi should I be using with these non stock tires? For now, I will not be towing anything and i'm looking for the best ride.
mikenj is offline
post #2 of 4 Old 04-14-2011, 03:32 AM
agreed just got e rated toyo m/t 37/13.50/20 and im not sure either
2003 F-350 CCLB 7.3L XLT Sport FX4
7.5" Custom Superlift, 37" Toyo M/T, 20x10 Black Fuel Hostage, 4"-5"-6" Black Aussies, 20% Tint, 05 Harley Headlights, Recon Lighting, Dixie Horns, 08 Mirrors and Taillights, 05 Emblems, Custom Audio/Video System, Billet Grill, HID's, 2 Yellow Top Optimas, N-fab Black Nerf Bars, DIY 6637 Intake, Foil Delete, & TGC Dual steering stabilizer, Wicked Wheel, Isspros & DP-Tuner.
landyacht27 is offline
post #3 of 4 Old 04-14-2011, 03:38 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
its time for summer air in those tires. let out the winter air asap.
they should be the same. 80 psi for e loads. might be 65 on d loads.
i ran the 265s on my obs and it was fine.
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
post #4 of 4 Old 04-14-2011, 04:04 AM
You dont have to run max pressure. 80 psi is max on e rated. I had some large 13.50 wide e rated tires and max was 60. Read the tire. If max is 80 try putting 70 in front and 60 in the rear and see how you like that. The motors are heavy so dont go real low in the front. You dont want to go too low in the rear either. The tire is designed to have a good amount of pressure.
2008 6.4 f250 lariat 4wd
melmount is offline
