Split shots (AB's) (AD's) - Page 3 - Ford Powerstroke Diesel Forum
post #21 of 106 Old 01-22-2012, 12:56 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
The best option for a OBS Ca split shot is to swap out the PCM to a 48 state PCM and rewire the harness..easy takes 1 hour max..
Ca splits are larger than the 48 state 98cc..they are aprox 120cc.
The 160cc single shots with the stock turbo and fuel system works great and get just about 2x's the rear wheel HP that a stock OBS gets..plus great mpg's.
CT Performance, Inc. is offline
post #22 of 106 Old 01-22-2012, 01:05 PM
sgt dave's Avatar
Quoted: 3 Post(s)
my truck is a 96 california model. when i installed my AC codes i had my wildman chip tuned to run them. truck is a different animal with these injectors
1996 F250 SC/LB, 4x4 PSD, ATS stage 1 trans 5 star tcc, AC codes,TW tunes, magnaflow 4" exhaust, 6637 , FS 2500 bypass oil filter,pure power reusable oil filter, isspro gauges, dieselsite cpr fuel pump system, adrenaline hpop, pml rear diff cover ,ebpv delete,non epbv pedestal, king pin dana 60, swamps idm, tru cool 4739
USMC 1993-1998
Plumbers & Pipefitters L.U.447
sgt dave is offline
post #23 of 106 Old 01-22-2012, 01:47 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
Feedback Score: 4 reviews
what cc is ac codes? and why swap the pcm cary? are you saying the 98 single shot is better? or are you saying go stage 1 single shots?
-Kris-
2000 excursion V10 2wd 230k
2000 Excursion 7.3 4x4 246k
1995 CCLB DRW 324K
2001 CCLB DRW 319K
Originally Posted by JJFLASH
351fifty is offline
post #24 of 106 Old 01-22-2012, 01:51 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
AC codes are internationals High Output injectors. They flow 160cc
you wanna swap the PCM or else things get really messy when you try to fire a single shot injector twice like that
Trucks and parts............
kanuck15 is offline
post #25 of 106 Old 01-22-2012, 01:54 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
dont custom tunes remedy that situation?
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #26 of 106 Old 01-22-2012, 01:55 PM
kanuck15's Avatar
Quoted: 10 Post(s)
They can but you are better off with a PCM swap. That way its all intended to run together. You arent fighting the over all programing of the truck
kanuck15 is offline
post #27 of 106 Old 01-22-2012, 01:58 PM
DERAIL MOD!!!
351fifty's Avatar
Quoted: 3 Post(s)
so if/when i go to hybrids i should swap my pcm or keep custom tunes since mine is factory splits
-Kris-
1995 CCLB DRW 324K
2001 CCLB DRW 319K
351fifty is offline
post #28 of 106 Old 01-22-2012, 02:01 PM
kanuck15's Avatar
Quoted: 10 Post(s)
That is something you will wanna talk to your tuner about. It all depends on what strategy you go with and whatnot.
kanuck15 is offline
post #29 of 106 Old 01-22-2012, 02:09 PM
sgt dave's Avatar
Quoted: 3 Post(s)
i havent had any problems with my tuning or with my truck. truck runs great. you could never tell i went from splits to singles
USMC 1993-1998
sgt dave is offline
post #30 of 106 Old 01-22-2012, 02:23 PM
kanuck15's Avatar
Quoted: 10 Post(s)
See some people have luck, others have gremlins that cant be tracked down. Id probably do it the hard way and try tuning a split shot computer and when that doesnt work just get a single shot computer
kanuck15 is offline
