5 inch exhaust question - Ford Powerstroke Diesel Forum
post #1 of 17 Old 04-07-2011, 10:38 AM Thread Starter
I have a 1995 f350 7.3l psd. I am looking to upgrade my exhaust to reduce backpressure and also to make it sound louder. I want it to sound deep and also give a good whistle. I ran across this kit from diamond eye.....
Diamond Eye Aluminized 5" Exhaust Ford 7.3L
Its a cat and muffler delete with 3" downpipe and 5" the rest of the way. First question is are there any setbacks to cutting out the cat and muffler and running straightpipes? and second is it even worthwhile to have a 5 inch exhaust with it still bottlenecking at the downpipe? will it sound good? does anything larger than a 3" downpipe fit behind these engines in this year? thanks for the help.
Dixie_Motorsports is offline
post #2 of 17 Old 04-07-2011, 10:52 AM
mjones3586's Avatar
3 inch DP is all you need the turbo has a 3 inch outlet on it and it takes a little work to do there is a good write up on that for sure helped me...as far as the cat and muffler delete i did it and made a worlds of difference on my 95 and my buddys 01 and 5 inch exhaust to me is a little to much but no comment to that i will let someone else tackle that but thats my 2 cents
"Diesel Head and Machinist"
4 inch lift o 36"s
3"DP to 7" Mitre Cut Stacks no cat/muffler
mjones3586 is offline
post #3 of 17 Old 04-07-2011, 12:25 PM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
No gain going larger than a 4" pipe...
You can get kits with a 3-4" DP..PM me if I can get you one.
Cary
CT Performance, Inc. is offline
post #4 of 17 Old 04-07-2011, 12:32 PM
CowboyCody's Avatar
yeah, 5" is a little overkill. A 5" tip might be ok though and would give you the same look
Originally Posted by madpowerstroke View Post
Try spinning a turbo with compressed air and hit it with diesel clean as you inhale at the turbo outlet, I call it a turbo bong.........that's some good stuff, makes you come up with all kinds of crazy ideas.
2010 F450 Super Duty Lariat Ultimate, 140,xxx Miles. 5" DP Back. Black Maxx. AFE Pro 5R Stage 2. ARP studs new heads and gaskets.
CowboyCody is offline
post #5 of 17 Old 04-08-2011, 06:11 AM Thread Starter
Ive heard the 5 inch does nothing for performance but will it be louder than the 4"?
post #6 of 17 Old 04-08-2011, 11:24 AM
Quoted: 3 Post(s)
Yes it is...
post #7 of 17 Old 04-09-2011, 07:18 AM
Dixie,
In my own experience, I personally would only do 5" exhaust if you're gonna do stacks. I had a miserable afternoon helping my friend rehang his 5" under-truck system and getting it to be completely rub-free. There was some creative heating/bending/hammering going on and we must have taken it off the truck about 15 times that day. I told him... if it starts buzzing again... sell the truck.
One of the problems I had with my 3" DP is getting the bloody thing to clear through such a tight space between the firewall without rubbing. Right now it only gives me noise at high negative torque on the driveline, so I'm not gonna bother with it for now.
ekfinn is offline
post #8 of 17 Old 04-09-2011, 10:04 AM
studdgage's Avatar
my 5 inch kit went in easy no problems but take it from me dont run nothin over 4 inch 5 is over kill and i dont think it was any louder then my buddies 4 inch but my kit came with a 4 inch DP into 5inch exhaust as far as gains pretty much none i actually felt i might have lost a touch the only thing i did notice is the turbo spools up a bit quicker. Im buying another 7.3 tomorrow it is only goin to get a 4inch on it. Something that helps with the sound though is a nice big tip a 4 into 6 inch tip changes the sound atleast for my buddy it did and made it sound a little deeper.
Some people are like slinkies they are completely useless but they still bring a smile to your face when you push them down a set of stairs
studdgage is offline
post #9 of 17 Old 04-09-2011, 10:19 AM
Full A-Team Member
Fordman247365's Avatar
What year of truck is this? A 4" DP wont fit on an OBS and for that matter if its a super duty dont even bother trying to compare its sound to an OBS. Yes 5" is overkill and has ZERO performance gain...but, a 4" system on an OBS truck will still have a little bit of the 'slapping' sound where a 5" system has a deeper, smoother sound. My opinion to the OP, put in what YOU want to put in. If its deep, smooth, turbo sound you are after, then do the 5"
Elmo/Shane
96 F350 4x4
Everything.
And its expensive.
476,000 Miles
"100% worked for, 100% paid for"
Fordman247365 is offline
post #10 of 17 Old 04-09-2011, 10:54 AM
studdgage's Avatar
Both mine and my buddies truck is a 2000 7.3 liter and the 4 inch DP went in No problems
