Got Me a Long Block!!
Im gonna put a new HPOP on, what else should I put on new. Gonna get my old injectors checked out and then probably get new gaskets. Any tricks would be helpful also.
Thanks Craig |
rebuild the oil cooler. consider an electric fuel conversion...
If your injector's are high mileage send them in and have them turned into stage 1 injectors.
Replace every seal you can BEFORE you put the engine in the truck.
Or you'll be doin a few seals with it in there. |
What about IPR and ICP. Where is the best place to get seals, is there a kit you can buy?
Any of the big shops should have a line on them. eBay will have them too. I wouldn't mess with the IPR or the ICP sensor unless it looked like they needed attention, probably not a bad idea to replace IPR o-rings though.
get a new oil pan just incase
