Another 95 F-350 CC project. - Ford Powerstroke Diesel Forum
Old 03-09-2011, 02:37 AM
This used to be my daily ride but I think its going to become a project truck (just to pull big trailers, horse trailer and hay trailer). Im going to have to find me a new truck so Im going to have to do this on a budget. Included are some pictures of the old buggy. Its a little dirty I just got back from feeding. Any suggestion will be appreciated.
1995 CC dually custom fiberglass running boards and Visor
7.3 ps stock(no mods)
5 speed manual
Gear Vender Overdrive
4.10 rearend
Around 300,000 miles
do compression check
need Autoenginuity with Ford Bundle
intended Mods
move batteries to behind the cab
(use welder cable to rewire batteries)(have cable)
(bus bar mod in engine compartment include DC to AC inverter)
spoiler on the back of the cab (air intake above spoiler)
(run 4inch exhaust pipe to box with tymar type filter- from filter to intake)
intercooler (I already have the intercooler just need spider and tubes)
Injectors,HPOP,Tune (looking for around 300hp, talk to the tuner people about injectors)
AB injector(130 cc) stock (I think this is about all the old engine can take and be reliable)
HPOP- 17*
Tune for pulling
ICM mod
install guages (Pry,Boost, and Fuel press.)
Driveline
Rearend to 4.56 LS ?(10.25 inch rearend can I just replace ring and pinion to LS and then change gears)
Transmission to 6 sp ?(types of clutches)
Glow Plug
The Stancor relay works pretty good but Im tired of checking GP's and the damn thing is a pain.
Build a SS curcuit to replace GP relay (include curcuit to check glow plugs. Warning light when glow plugs are going out.)
One more mod (climate control) great mod
Another 95 F-350 CC project.-dscf0211.jpg   Another 95 F-350 CC project.-dscf0212.jpg
Old 03-09-2011, 04:51 AM
Nice cc and a great base for a project truck. Post lots of pics as you go.
Old 03-09-2011, 05:05 PM
Electrical Ogre
I like the idea of a solid state setup to replace the GPR. I've never looked into it for 12 VDC, but solid state relays exist. Post up a schematic for the glow plug check circuit when you got it figured out.
