swap 10.25 for 10.5 axle?? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 03-06-2011, 07:49 PM Thread Starter
ok guys so i was driveing my 96 f250 the other day and all the sudden my rmps and speddo maxed out and i wasnt moving. pulled over to try reverse and drive still wouldnt move just revd up. i left it in gear and got out and the drive shaft was spinning and i wasnt moving. took rear diff cover off and everything was fine. so i pullover the axle shafts out and one was broke. wheel bearings and everything on that side were bad too the shaft dented up the axle tube so it is no longer usable. so my ? is can i put a 10.5 rear axle under a OBS? if not does anyone have a 10.25 for sale with 3.73 or 3.55 gears?
thanks guys
96 F-250 ext. cab long box 4x4
Intake, auto meter(oil psi, tranny,boost, EGT) IDM mod, .030 over rebuilt motor, comp 910's, BDP d66 turbo, BDP stage one injectors, BDP fuel system, t500, BDP custom tuned 6pos, coolingmist water/meth, 3in downpipe 4in duals, dana 60 swap, 203* t-stat
traction bars, 6.0 intercooler
furture plans,
BTS, 300/200 sticks, studs, pushrods, t4 mount, NEW PAINT
GOAL= 600+ hp
stroked out is offline
post #2 of 4 Old 03-07-2011, 11:38 AM
Quoted: 4 Post(s)
Feedback Score: 5 reviews
Can you use a SD axle..yes but will need SD rims.
I have a '97 4.10 with 90k miles if interested..
CT Performance, Inc. is offline
post #3 of 4 Old 03-07-2011, 01:46 PM
95ef2fiddy's Avatar
just get wheel adapters
1997 f250 7.3
regular cab
tw chip
3 inch dp
4 inch cat delete
5% tint
glow shift gauges
6 inch cat stack
completely rebuilt kp d60
3 inch rsk
24s
38s
zf5 swap
southbend clutch
d66 turbo
4 inch skyacker springs
7 inch rear block
traction bars
bdp complete fuel system. (bowl delete and elec pump)
beans stage 2 injectors
intercooled
95ef2fiddy is offline
post #4 of 4 Old 03-07-2011, 08:48 PM Thread Starter
I found a rear end here in IL for 150 bucks good deal? its a 10.25 with 3.55 but its a open diff.
can i take the limited slip out of my axle with 4.10 and put the ring gear from a 3.55 onto it?
furture plans,
GOAL= 600+ hp
