power difference from 94-98 and 99-03 7.3 - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-05-2011, 07:53 PM Thread Starter
I am pondering which year I would like to buy and it seems like the newer 7.3s have more torque/hp. was this all due to computer programming? also, my brother and dad both have 97 7.3s and I guess those were lower than the 95/96? I have yet to find a spec sheet for all the years of the 7.3, so if anyone knows where I could find one please let me know!
ford_tamer is offline
post #2 of 9 Old 03-05-2011, 08:00 PM
JJFLASH's Avatar
Quoted: 111 Post(s)
94.5 - 97 were BASICALLY the same.
Early '99 added intercooler, different injectors, different turbo.
Late '99 added different injectors, turbo and high pressure oil pump.
2000 and only 2000 had I think forged rods.
Stayed about the same till the end in '03.
95-96 were not lower numbers than '97.
Hope that helps a bit.
-JJ-
Mine - 94.5 F250 ZF5: Basics w/a few extras, DIY bumper, steps and exhaust, AFEII, D60, PMF 2.25 RSK, V-codes
Hers - 04 GM 2500 CCSB 4x4: LB7, EFI Live by KW, 2" Lift, MBRP 4" dp back
RIP 15/08/23- 98 GM 1500 ECSB 4x4: 6.5, straight pipe, K+N filter, 495km w/original pump, trans & t-case
JJFLASH is offline
post #3 of 9 Old 03-05-2011, 08:12 PM Thread Starter
thanks for the quick reply! I meant that I heard the 95/96 were more snappy than the 97, but maybe not true. I've been reading that the pmrs were used starting in 2001 except for certain block numbers..
post #4 of 9 Old 03-05-2011, 08:17 PM
JJFLASH's Avatar
Quoted: 111 Post(s)
I can't comment on specific numbers and stuff cause I'm not the authority, I just like 'em lol.
There are some serious gurus on here that will be able to answer any question you can think of so just keep bumping your thread.
And welcome to the addiction...I mean welcome to the ORG
-JJ-
JJFLASH is offline
post #5 of 9 Old 03-06-2011, 08:55 AM
the baconator
terryknight's Avatar
Quoted: 143 Post(s)
What JJ said is correct.
94.5 -96 were 210 or 215 97 was 225 the SD got even more of a bump in power I think by 03 some SD had 275, but it think that was only the manual. powerstrokes up until 00 had the forged rods. some 01 did too, but I don't know which ones
94.5 F250 Reg Cab 4x4 5 speed 4.10 276000 plus miles
97 F350 Crew Cab LB 4x4 5 speed 3.55 320000 plus miles (parts truck)
Originally Posted by alberta 7.3 View Post
YouTube: Providing idiots everywhere a podium to share their stupidity
terryknight is offline
post #6 of 9 Old 03-07-2011, 07:24 AM
ridiculously_necessary's Avatar
95 - 97 had 9x cc injectors. e99's had 120cc i think? and i think after that they were 140's. all e99+ were split shots. tehy also have an intercooler. more power stock, adn definitly more power chipped. the OBS single shots usually get better mileage. when the SD guys go to single shots they usually report better mileage as well.
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #7 of 9 Old 03-07-2011, 07:37 AM
superduty4x4's Avatar
Nope, backwards but it depends on the truck.
Most 94.5-97 trucks have 90cc AA code single shot injectors.
Late 96 and 97 CA emissions model trucks have AB code 120cc split shot injectors
E99 trucks also have AB's
Latee99-03 trucks have AD code 140cc split shot injectors
Single shots make more power (all the fuel is expelled in one shot), the split shots were introduced to lower noise and emissions (the split shot name is because there is a small pilot shot of fuel before the main injection event)
SD trucks also have higher voltage IDM's that improve throttle response slightly.
Oh and PMR's actually started in 00 some time for a short duration, then back to forged for a bit, then PMR's again.
97 F350 CCLB 4x4 PSD
superduty4x4 is offline
post #8 of 9 Old 03-07-2011, 07:55 AM
late_99_PSD's Avatar
Quoted: 10 Post(s)
I pulled this off of this site Power Stroke Diesel Timeline
1994
210 @ 3,000 425 @ 2,000
7.3 L direct injection, turbocharged 17.5:1 compression
1995 210 @ 3,000 425 @ 2,000 CA trucks recieve split shot injectors.
1996 215 @ 3,000 450 @ 2,000
1997 225 @ 3,000 450 @ 2,000
1998 225 @ 3,000 450 @ 2,000 All 7.3L Power Strokes now have split shot injectors.
1999
235 @ 2,700 500 @ 1,600 7.3 recieves intercooler, smaller turbo, larger 120cc injectors
2000
2001
250 @ 2,600 (auto trans)
275 @ 2,800 (man trans)
505 @ 1,600 (auto trans)
525 @ 1,600 (man trans) 7.3 calibration increases horsepower and torque
2002
275 @ 2,800 (man trans) 505 @ 1,600 (auto trans)
2003
Arrival of the 6.0 L Power Stroke. Both 6.0 and 7.3 offered for 2003.
2003 (6.0) 325 @ 3,300 560 @ 2,000 VGT, EGR, OHV 4v 6.0
2004 325 @ 3,300 560 @ 2,000 7.3 discontinued, not available.
2005 325 @ 3,300 570 @ 2,000 6.0 L Torque increase
2006 325 @ 3,300 570 @ 2,000
2007 325 @ 3,300 570 @ 2,000
2008 (6.4) 350 @ 3,000 650 @ 2,000 OHV 4v, common rail, sequential turbo 6.4 L introduced
2009 350 @ 3,000 650 @ 2,000
2010 (6.7) 390 @ 2,800 (original)
400 @ 2,800 (updated) 735 @ 1,600 (original)
800 @ 1,600 (updated) 6.7L Ford Power Stroke replaces 6.4L International Power Stroke. Horsepower & torque upgraded in August/September.
2011 400 @ 2,800 800 @ 1,600
Allen
1999.5 F-350 7.3, six-speed
late_99_PSD is offline
post #9 of 9 Old 03-07-2011, 05:19 PM
JJFLASH's Avatar
Quoted: 111 Post(s)
^^^ now that's a pretty sweet chart
-JJ-
JJFLASH is offline
