High pressure fuel line, in aluminum - Ford Powerstroke Diesel Forum
Old 03-04-2011, 10:18 AM
I'm trying to source out some aluminum fuel line so I can redo my OBS
I'm running a high pressure electric fuel system and had my heart set on redoing the whole truck and using aluminum lines, along with -6AN fittings and tube nuts.
My problem is that the fuel lines I keep finding are rated to 25psi.
Will it work? I'm not into steel lines, and don't want rubber lines.
Any one have some thoughts on this?
Thanks,
AB
Old 03-04-2011, 10:20 AM
i saw some aluminum tube on amazon when I was looking at doing mine.....
Old 03-04-2011, 10:22 AM
What was the pressure rating?
I've been looking at 3/8 thin wall.
Maybe moving up to a thicker wall, or going 1/2" might help.
Old 03-04-2011, 10:46 AM
Found it, rated to 250psi
Now to double check the compatibility and validity of their claims.
Aluminum Fuel Line
Old 03-04-2011, 11:32 AM
are you going with aluminum because of the WVO?
Old 03-04-2011, 12:05 PM
Yep, u got it.
Hot WVO and steel don't mix well in the long haul.
Old 03-05-2011, 12:08 PM
Electrical Ogre
Talk to a local hose/hydraulic shop. Usually they have knowledgeable guys and everything in one stop.
