Trans gauge questions - Ford Powerstroke Diesel Forum
Old 02-28-2011, 06:30 PM
I will soon be ordering a sender for a b&m gauge there are three posts on the back i know one is ground and one is the wire for the sender but what is the third?
Also wht is normal running temp for a 1996 f350?
is the pressure port on the trans a good place for the sender?
off topic question... when i plug my fog lights up they don't light up. but when i press one wire to the battery and use a test light the complete the circuit the test light lights up is this right?
Old 02-28-2011, 06:39 PM
the third contact would be for the light
temps will depend on the condition of the trans but anything over 180 could get ugly
on the a4od the proper place for the sender is in the pressure check port on the drivers side just above the front corner of the pan.
are the light sockets corroded?
Old 02-28-2011, 06:49 PM
Sry it has three posts and a separate connection for the light.. thts what confusing me?
They weren't corroded at all its so weird the light is able to make a circuit but not glow weird...
Old 02-28-2011, 06:58 PM
ok you got me. more familiar w/ autometer gauges. thats the layout on those. maybe check the b&m website for install diagram.
check for power through your light plugs with the test light. if you have power from hot to ground at the plug then the problem is the lights
Old 02-28-2011, 07:01 PM
wow its always the simple things i forget to try
