Conversion to 4 wheel drive - Ford Powerstroke Diesel Forum
Old 02-22-2011, 09:42 AM
Well i would like to say it seems pretty worthless to have a 1ton++ truck only being 2 wheel drive. i drive 15 miles each way to work every night and we have 9 inches of snow.... What an interesting trip home
Well i have a 1997 F450/fsuperduty its got the 7.3l powerstroke with the zf5. Its got 141k and it runs like a new truck.
I want to convert it to 4x4. Would a straight axle conversion be the easiest route to go??? my truck has 4.63 gears in it and i didnt know if i could find a front axle with 4.63 gears and if i could whats the chances it would be a 10 bolt lug pattern.
now when i put a tcase in is there any electronicsto it or just manual tcase. Do i have to change the trans to a 4x4 zf5???
WHats your opinion on this.....???? Should i just find a donor f350 4x4 and just go that route i really dont know what all i would have to do
Old 02-23-2011, 06:25 PM
not sure about the tcase hook up but i would pick up 2 axles front and rear with 4.10s. In the 80s they made dully 4x4s. The 4.10s will help fuel milage alot.
Old 02-23-2011, 10:35 PM
can i go any higher on gear ratio or no???
Old 02-24-2011, 04:14 AM
The F350 SRWs you could pry find a set of 3.55s if you looked hard enough
Old 02-24-2011, 04:35 AM
Full A-Team Member
Rest assured they made dually 4x4's in the 90's and 00's too
The easiest way would be a donor 350, need trans, transfer case, front end, rear end(unless you want unmatched wheels) not sure on the wiring, I dont think the psd requires wiring on a manual trans to run correctly.
Old 02-24-2011, 04:54 AM
Feedback Score: 7 reviews
Send a message via AIM to dereku
No they didnt make 4x4 duallys in the 90s. They are all conversions.
Old 02-24-2011, 04:59 AM
Full A-Team Member
Maybe I missed something, are we talking 350 or 450 dually? I can go find you 5 or 6 350 dually's right now for sale thet I can tell you are work trucks that havent been to a conversion shop
Old 02-24-2011, 05:05 AM
They did not make 4x4 dually's in the the 90's, I didnt think they made them in the eighties
Old 02-24-2011, 05:08 AM
Full A-Team Member
Well either way, conversion or not, they are not rare, in 5 minutes of looking I found 3 90-97 F350 4x4 dually's for sale here so finding a truck to get parts from shouldnt be a problem
Make that 5 I just found 2 more
Old 02-25-2011, 08:48 AM
well i posted an add on craigslist for axles for my f450 i have a dana 80 in it with 4:63 gears. some one has 8 bolt dually axles from a f350 with 2:73 gears. could i use that or is that even possible to use. I dont do alot of pulling.
also for doner trucks for this project i have access to 3 fsuperdutys, 3 f350s, 7 f250s. only 2 have powerstrokes. But i cant wait to get the utility bed off my truck. i have a western hauler bed or a dually bed to put on i dont know yet
