2wd F-350 lift?? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 02-20-2011, 04:25 PM Thread Starter
Trfytow's Avatar
2wd F-350 lift??
Im looking for a suspension lift for my 97 2wd F-350. Only one I have found is the Fabtech 4" which is perfect except they are back ordered indefinitely. Anyone know of something?
I also found this, not sure if my front end is the same though...
Ford Van Suspension lift kit for off-road action van
Thanks for any help!
Trfytow is offline
post #2 of 7 Old 02-21-2011, 06:22 PM
Aaron Berk's Avatar
I need a 2wd lift also, when is the market going to catch up to us diesel guys?
Every lift says "not for diesel"
97 F250 ext cab lwb 4x2
AirDog2 and FASS HD (it's a WVO RR setup)
Simple Centrifuge filtering method
203 degree Mod, DIY homegrown intake, CCV mod, battery relocation,
215amp Ambulance Alt.
EBPV gut, Pedestal gut & cut
Diamond Eye 4" (3" dp) turbo back straight pipe
no kitty, no muffler
Aaron Berk is offline
post #3 of 7 Old 02-22-2011, 05:20 PM Thread Starter
Trfytow's Avatar
Trfytow is offline
post #4 of 7 Old 03-04-2011, 09:05 AM
Aaron Berk's Avatar
FOUND THIS TODAY
Not sure if it works, but it's a glimmer of hope.
I know the title saws 4wd, but I bet the front spring perches are pretty much the same.
Skyjacker Suspensions F825K - Skyjacker Suspension Lift Kits - Overview - SummitRacing.com
post #5 of 7 Old 03-05-2011, 07:36 AM Thread Starter
Trfytow's Avatar
Only problem is the F-350 2wd trucks do not have leaf springs in the front at all. I-beams with coils.
E-series van is completely different. No one makes anything so I bought a 99 SD.
Trfytow is offline
post #6 of 7 Old 03-05-2011, 07:55 AM
ryandamo's Avatar
1987 Ford F250 Buildup - Rancho Shocks - Diesel Power Magazine
article in diesel power mag a few years ago, im in the process of leveling my 2wd when i get around to it, purchased some spacers for 99-04 2wd trucks, hopefully the stud extender works. anything over 2 inches will require drop brackets for the pivot arms since a camber bushing can only do so much.
http://shop.ebay.com/?_from=R40&_trk...All-Categories
there is a bunch on ebay, the only reason these wouldnt work is if the stud extender is a different thread, your local hardware store should be able to get the correct one if this is the case
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #7 of 7 Old 03-05-2011, 10:22 AM
Aaron Berk's Avatar
That's kinda funny, "No one makes anything so I bought a 99 SD"
I guess that's one way to solve a technical issue.
That link I posted does have front coils, and rear add a leafs. But it was only a little lift, not really worth it.
I'm personally keeping my eye out for a 4" lift. Nothing crazy, just a simple lift.
