94 w/ 96 motor 5 speed manual 4x4 6 speed conversion
My buddy has a really clean 94' with a 96' 7.3 in it thats attached to a 5 speed (yes its 4x4) and we are going to do a clutch in it...well we have both been debating a 6 speed conversion..anyone know what it would take????? is it possible? Does he need a 6 speed and transfercase or will his t case work??? Any input,ideas,write ups, etc would be great!!!!!!!!!!
6 speed trasmission, 6 Speed clutch and flywheel for 99-03, a 99-03 slave cylinder, You will need a 6 speed transfer case with a 24 spline input shaft. you will need to take the 5 speed trassmission spacer out. 6 speed will not need it. You will have to pound on some sheet metal to make it fit. make your drive shaft shorter and lenghthen you 4x4 shaft. And get a six speed stick. That about covers it
Why exactly do you want to go to the six speed? In the end, the total range of gear ratios (1st/grannygear vs overdrive) is nearly the same in the 5 speed vs the 6 speed. I wanted to do a six speed conversion (before I realized how involved it was) when I wanted to drop highway RPMs for fuel savings. In the end however, the 5 speed would basically give me the same gear ratio has the 6 speed in the top gear. Consider this too: these engines have ample torque to deal with the larger gear ratio jumps in the 5-speed, and larger gear ratio jumps means less clutch use, less clutch use means fewer times that you'll be doing what you're doing now and replacing clutches (which are a bit pricey). |
AT 2000RPMs, 4:10 gearing you will do 60mph with 5 speed, But with the 6 speed in you will do 64mph at 2000RPMs with 4:10 Gears
But if you are lucky and have 3:55 Gears, At 2000RPMs with the 5 speed you will do about 70mph. But with the 6 speed and 3:55 Gears at 2000RPMs you will do about 74mph You will not wear you clutch out any faster with the 6 speed then you do the 5 speed. you dont even need 1st (Granny low) for every day driving. just when you tow then the 6 speed will realy shine. |
