97 F350 farm truck R&R - Ford Powerstroke Diesel Forum
Old 02-16-2011, 06:08 AM
I've known the front end was sagging since I bought it back in September, but I put that on the backburner while I took care of a few more pressing issues.
I'm getting ready to throw some new shoes on it, so I figured it was time to take care of the front end sag so I could try to fit a little bit bigger tire on it if possible.
First off, I have a pretty big bumper on the front with a big ole hydraulic winch in it. I don't know how heavy the combo is, but I know it's more than a factory bumper.
I'm sure that having all that weight cantilevered out front for the last 14 years has put a little extra strain on the front suspension.
Here's the truck in profile. You can really see how much higher the rear is than the nose.
Here's the door sticker on my truck. I don't know if it will give any info, but it's worth a shot.
My questions:
Whats a good way to get the nose back up a little without doing a lift?
Can I put the front springs from a heavier truck (ie F-Superduty)? Will that make a difference in height or will it help at all?
Here are a few more pictures.
I have more pictures. If there is anything specific that anyone wants to see, just ask.
Thanks,
Adam
Old 02-16-2011, 12:00 PM
Am I seeing things or is that diagonal bar on the front end severely bent? If it is that can't be good. I stuck a 9-1/2' V-plow on the front of my F250 and it caused me to redo the front springs to level it...it works and makes a big difference. Some of the 4x4 fellas on here will be able to help you out with the right approach.
Old 02-16-2011, 12:12 PM
drives a ranger
Send a message via AIM to kanuck15
Id look into getting something like a 2 inch lift spring for the front. That bumper is killing it on top of having a 1000lbs motor on them as well. Idk if you know this or not but someone converted your truck to dually. Its supposed to be a SRW truck. Not that it matters but still some info.
Old 02-16-2011, 01:16 PM
Yeah, the drag link is bent. It's on the to-do list.
Yeah, There's a lot of extra weight on the front. Do you know if any of the aftermarket suspension folks sell only the front springs?
Aside from the front having non-dually wheels/hubs, is there any way to verify if it was originally srw or drw? I'm going to keep it drw, so as far as that goes, it doesn't really matter. Just curious.
Originally, I was going to replace the front rotors with the correct drw width parts, but I'm thinking about leaving it alone and running a wider srw type wheel up front.
Old 02-16-2011, 01:45 PM
drives a ranger
Well the GVWR is the same as my SRW 350 thats the same cab/bed as yours. usually DRW means heavier GVWR.
Check out suspensionconnection.com they sell individual springs at varying lift heights
Old 02-17-2011, 05:52 AM
Anybody know what the GVWR would be on an a factory built drw regular cab/chassis truck?
I checked that site out. I wonder why 4" lift springs are cheaper than 2".
2" - $599.36 Ford Leaf Springs - Ford 1986-97 F350 4wd - 2" EZ-Ride front leaf springs (pair)
4" - $381.56 Ford Leaf Springs - Ford 1980-97 F350 4wd - 4" EZ-Ride front leaf springs (pair)
Old 02-17-2011, 08:29 AM
drives a ranger
try searching the part number now for the 2" springs, might find a deal
no clue on the GVWR, could you get a chassis cab 350? thought that was only a super duty (450) thing
Old 02-17-2011, 09:34 AM
I'll keep looking for the springs.
Here's my VIN info: 1FDHF36FXVEA30434
World Manufacturer Identifier - 1st, 2nd, 3rd Positions:
Manufacturer: Ford Motor Company, USA
Make: Ford
Vehicle Type: Incomplete Vehicle
Brake Type and GVWR Class - 4th Position:
Brake System: • Hydraulic brake system, Class G, GVWR 8,501-9,000 pounds, None
Line Series, Chassis Type, Body Type - 5th, 6th, 7th Positions:
Line Series: F-Series - F350
Chassis Type: 4x4
Body Type: Pickup - Regular Cab
Engine Type - 8th Position:
Engine: 7.3(445cid) DI-Turbo
Cylinders: V-8
Fuel Type: Diesel
Horse Power: TBD
Model Year - 10th Position:
Model Year: 1997
Assembly Plant - 11th Position:
Assembly Plant: Kentucky Truck: Jefferson County, Kentucky
Production Sequence Number - 12th - 17th:
Sequence Number: A30434
Old 02-18-2011, 05:48 AM
New center steering link (drag link) ordered.
So I was doing some thinking last night. I'm finding 4" suspension lifts (front and rear) all over the place for cheap (less that or equal to the price of the front 2" lift springs). If I lifted the truck 4" front and rear, What size tires would I be able to clear? How would that affect the driveability/usability of the truck?
The only thing I'm thinking is that I may still have a lower nose because of the bumper/winch.
Old 02-18-2011, 08:56 AM
drives a ranger
Well what you could do is do a hybrid lift in a way. lift it 4 up front and say 2 in the rear or 3 depending on what makes it level. Also try looking into Sky manufacturing for their RSK kit, its a 3 inch lift and it makes them ride better to an extent
