I've got a couple questions - Ford Powerstroke Diesel Forum
Old 02-10-2011, 06:51 PM
Send a message via AIM to Clouse2411 Send a message via Yahoo to Clouse2411
So instead numerious threads, I figured I would post them all in one. Not really a specific topic, just a bunch of questions that have been going through my head.
1. Is there a way to correct my speedo? I'm running 35's now and would really like to find out my true mileage. I know there are boxes, like superlift that will do it. But is there anyway cheaper?
2. I've been having trouble starting my truck in the cold. It cranks and everything just fine. The check engine like comes on sometimes and then its done for. I understand it isn't getting enough voltage to fire the injectors. Is it time for new batteries?
3. Also what truck do this intake spyder come off of? I need something to fit my 3in plenums I'm putting on when I do my intercooler.
4. I recently got a different set of gauges and my most gauge flutters around alot. Is it a boost leak in the gauge line or what?
If I think of anymore I'll just post them here.
Thanks guys.
Old 02-10-2011, 08:47 PM
spyder comes off the early 99 trucks can find them on ebay
Old 02-11-2011, 05:43 PM
[QUOTE=Clouse2411;2345643]2. I've been having trouble starting my truck in the cold. It cranks and everything just fine. The check engine like comes on sometimes and then its done for. I understand it isn't getting enough voltage to fire the injectors. Is it time for new batteries?QUOTE]
With the exception of the above question, I’m afraid I can’t help you with any of the others. First thing I want to tell you is I’m not a professional mechanic so all I can do is tell you my experience with my 96 F-250 turbo diesel. When you say you’re having trouble starting the truck while it’s cold, I assume you are using the block heater, correct? If you are using it, is this when it still gives you trouble. I live in the South and if I don’t plug mine up and the temperature gets below the mid 40’s, it will take me several times of heating the glow plugs before it will start. The colder it gets the more times it takes. However, this past fall I was having an issue where mine was turning over quite a few times before it would crank. I asked a mechanic friend of mine about it and he said to change the fuel filter. I kind of thought he was nuts and told him I didn’t think that would do any good but I’ll be darned if it didn’t do the trick.
You made the comment about not having enough voltage to fire the injectors. Since I don’t know the extent of your knowledge of diesel engines, please forgive me as I’m not trying to be smug but, I just don’t know if you know the following. Unlike a gasoline engine that needs fire, fuel, air and compression to start, a diesel only needs fuel, air and compression. A diesel engine doesn’t start with so called “fire” to the injectors as it sounds like you are saying. The only thing igniting the fuel is the compression of the fuel it’s self. You do, however, have glow plugs that help heat up the fuel as it enters the cylinder. That’s what the “Wait to start” light is for. If your batteries are weak and it’s not turning over fast enough this will keep the fuel from igniting and the engine from starting. Just recently, my batteries were getting bad and even though it would turn over with the engine warm, it still wouldn’t start. 2 batteries and $230.00 later, it starts fine.
Hope this helps
Old 02-11-2011, 06:12 PM
glow plugs heat the air not the fuel, you can check for power on the gp relay and make sure it is working, i think you can ohm test the glow plugs too to make sure they work as well...i was having problems starting last summer and it was the starter may wanna look into that as well
Old 02-11-2011, 06:34 PM
Full A-Team Member
Also, the motor needs to turn over fast enough to 'fire' the injectors. what I mean by that is it needs enough high pressure oil for the injectors to work
Old 02-12-2011, 09:34 AM
The motor doesnt sound to crank any slower than when it does with the check engine light on or off. Yes I do plug it in every night when I'm home and it usually starts right up. I let the gloiw plugs cycle a few times when it is cold and not plugged it. What would cause it to throw the check engine light and not start? What I've heard is the IDM has to have the voltage that it needs and when it doesn't, it throws a check engine light. Which I think that is what it's doing.
Old 02-12-2011, 10:23 AM
Plugged in at 40 degrees????? WTF. Up here I plug mine in when it drops under 25. At 40 it fires up instantly every time. I do have new batteries and known good GPR and GP's as well as a new alternator so can't tell you which is the culprit in your case but I'm sure the fellas here will help you find it. G/L
Old 02-12-2011, 06:30 PM
Well excuse me!!! I'm sorry mine doesn't fire up as good as yours!
Old 02-12-2011, 06:39 PM
I dont think he was being smart, he was just letting you know that you shouldnt have to plug it in at 40 deg... Im still trying to figure out why you fired back... Might be WTF but sometimes that just how others talk but i dont think it was in anyway putting your truck down
Old 02-12-2011, 07:01 PM
Full A-Team Member
To be honest, if it dont start at 40* there is something wrong in the glow plug system, possibly even deeper. I have 1 year old stage 1 reman injectors, 2 year old stancor relay, and 1 year old motorcraft glow plugs and there is anywhere from 250,000 miles on my engine to 450,000, there is 450,000 on the truck. It will start down to -10* not plugged in, I havent had it plugged in for more than 1 hour this winter and we just got done with 3 days in a row at -20* or lower. I dont even think about plugging it in if its above -10*
