If a 7.3 goes along time without an oil change can this cause the truck to not start - Ford Powerstroke Diesel Forum
post #1 of 15 Old 02-09-2011, 01:57 AM Thread Starter
Can it cause the engine to not build oil pressure for the injectors
Forrider is offline
post #2 of 15 Old 02-09-2011, 04:00 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Define a long time? But no not normally
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #3 of 15 Old 02-09-2011, 05:07 AM
Ryan Rønning's Avatar
Quoted: 6 Post(s)
It shouldnt, I would check other things first.
Project Frankenstein
1997 Ford F-350, Dually conversion, Cobra 29 LX CB, 12000 watt converter, All LED lights, PHP Hydra, 4" DP, Napa Intake, coolant filter, 140cc AD Injectors and lots of running lights.
Originally Posted by XPLOSIV View Post
Thanks. I'll give er a good wackin in the morning.
Ryan Rønning is offline
post #4 of 15 Old 02-09-2011, 06:47 AM Thread Starter
I'm not even sure how long I know it's been more then 5000 miles since the last change but my truck has been broke down for over a year it won't build pressure when I crank it the oil pressure gauge don't move like it use to. I got post all over about it on here they are way down the pages somewhere though but I just don't know where to start I'm hoping just an icp or ipr it prob needs a cam sensor too plus batteries and more! Its gona burn a hole in my pocket I don't wanna just throw parts at it that it don't need so what do u guys think I should do? Where should I start I know its something to do with oil pressure for sure cuz the injectors aren't spraying fuel out when u crank it it just cranks like it would do if it ran out of fuel any ideas ?
Forrider is offline
post #5 of 15 Old 02-09-2011, 10:43 AM
Cratos's Avatar
if its been sitting next time check the HPOP res I bet is is low top it off and see how it is with that said if it is low it will be time for injector o-rings . dash gauge is just and on- off switch for 7 psi for the computer it is not a true pressure gauge.
2012 F-250 4X4 FX4, SCLB, 3:55's , Camper & Tow package, air lift bags and pump, Edge insight. Dark Pearl Blue.
Cratos is offline
post #6 of 15 Old 02-09-2011, 12:31 PM
Mutley's Avatar
+ what cratos said. A drained HPOP will certainly cause your symptoms. At least you know the drain back works if it is empty huh? I would dump a bottle of Slick 50 or whatever you have in your neck of the woods in the HPOP along with some fresh oil....and change the oil/filters as well before firing it up. Sitting that long can't be good.
94.5 PSD Dually Crewcab F-350. Uglee, stock and reliable.
Mutley is offline
post #7 of 15 Old 02-09-2011, 03:44 PM Thread Starter
The reservoir keeps draining every couple days and the truck prob does need new injector o rings it has almost 300,000 miles on it is there any way to tell if they are bad like would they link oil out if I crank it with the valve covers off ? Does anybody think that itsprob time for new orings at 300,000 miles? And thanks for your info guys!
Forrider is offline
post #8 of 15 Old 02-10-2011, 05:41 AM
Mutley's Avatar
It's probably one of those "while you're in there" deals. I know I would if I had the covers off with that kind of mileage...prob GP's as well if they're that old.
Mutley is offline
post #9 of 15 Old 02-10-2011, 05:56 AM
southern7.3's Avatar
Hopefully mine will keep on rockin 310k and I haven't changed anything but the gpr and the cps
Sam
2005 F350 King Ranch CC DRW Insight Leveled 4" MBRP Straight Pipe Tinted
'99 F250 - Sold
'99 Cummins - Sold
southern7.3 is offline
post #10 of 15 Old 02-10-2011, 03:13 PM Thread Starter
Yea it needs some new plugs too but does anybody got an idea on how much a set of injector o rings for all 8 injectors would cost??
Forrider is offline
