Coolant temp gauge issue
Ok so I just picked up a 96 and the temp gauge dosen't come up even to a 1/4 way if it moves at all. I still get heat so I don't think the thermostat is stuck open but I'm replacing it anyway. I'm pretty sure there is a wire that runs to the gauge that I'll look into but is there anything else I should know about.
Nope sounds about right, mine barely rises, just before the N on normal is where mine runs, it is due to the cooler temp themostat that ford put in our trucks
go to www.dieselsite.com and get the 203* thermostat. That will fix the problem.
I can't belive they put that cool of a t-stat in them. Just thought it was low because my 00 and 01 ran higher but they must have changed the t-stat style. Gonna change it anyway PO wasn't big into doing much to the truck.
They put in a cooler t-stat cuz there wasnt an intercooler in the truck, the SD has an intercooler, thats why they let it run a higher temp.
IMO the 203* t-stat isnt an upgrade. I have had so many trucks in my life that run hot it is nice to finally have one that doesnt get hot when I work it |
In all the readding i've done i haven't really found any reason to switch other than "hotter" heat in the winter and the fact that IH used 203* t-stats in their trucks. If i have to replace mine i'll just get whatever is cheapest unless somebody does some testing and finds out if there is any advantage to either one. And honestly i don't see how 6* is going to even make a noticeable difference.
And to the OP, that sounds normal. I was running close to WOT the other day on the highway for a while and i don't think mine ever got past the O, usually its on the N. |
Almost done with that issue, just held up for lack of a $1.99 gasket.
