Quick question 96 F250. - Ford Powerstroke Diesel Forum
Old 02-04-2011, 09:29 AM
Possibly looking at a 96 OBS and it has this. No idea what this may be. I was thinking maybe a brake controller but it has one under the steering wheel.
thanks
Old 02-04-2011, 09:31 AM
I can't see the picture?
Old 02-04-2011, 09:34 AM
Ok did the photo as an attachment. work now?
Old 02-04-2011, 09:36 AM
Illiana Chapter Director
That is a PTO/High idle set up. That was an option for the 99+ Super Duty but wasn't aware you could get it for the OBS
Old 02-04-2011, 09:42 AM
Ah ok thanks. Would you use this for a quicker warm up?
Searching found this.
1995-1998 FORD POWERSTROKE AUXILLARY IDLE CONTROL 7.3 - eBay (item 130480517905 end time Feb-27-11 21:36:53 PST)
Old 02-04-2011, 09:44 AM
I'm sure you could. Most guys put a custom tuned chip in with a high idle setting which doesn't take up any space.
Old 02-04-2011, 09:48 AM
Thanks for the help. Hopefully check the truck out tomorrow.
Old 02-04-2011, 12:43 PM
Thats an AIC. Its better than just high idle on a tuner because you can set multiple high idle settings, put it in charge protect mode, and it has a digital volt meter so you can see how many volts you are putting out. I'll take if it you don't want it.
Old 02-04-2011, 01:56 PM
Truck isn't mine but more than likely buying it tomorrow.
Tags
obs
