6 speed taking off, Help? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 01-31-2011, 03:09 PM Thread Starter
Sulfer Addict's Avatar
Ok guys I cam from the cummins world and I knew takin off you didnt have to give it any throttle takin off from 1st in 2nd. So I got my PSD thinkn the same and even in L (1 of 6) I got to give it some decent throttle so she dosen't stall. So basically what am sayin is you got to drive it like a gas truck compared to driving a traditional diesel truck with a stick.
Thanks guys any suggestions about if I got a problem or if it is completely normal, maybe any ways to fix/change this.
2000 F-350 Ext. Cab Short Bed, 6 Speed, 2.5" Lift, Hydro-Clutch,155k, AFE Cold Air Intake, AFE Intake Manifold, Wicked Wheel, DP Tuner, Dual 6" Black Stacks, 305 Peak A/T, All Blacked out
1993 Ford Ranger XLT 4x4 4.0L 5 Speed- My Danger Ranger
EHOVE 13'- Diesel Technology
Facebook- Mike Verbiar
Sulfer Addict is offline
post #2 of 8 Old 01-31-2011, 03:59 PM
riddin' high
Dasaliac03's Avatar
Send a message via AIM to Dasaliac03 Send a message via Skype™ to Dasaliac03
if i put mine in low (granny gear) i dont have to give it ANY throttle to roll up the driveway. 1st gear will sputter a tad but wont stall, 2nd does need a little bit of pedal behind it
SOLD - '03 7.3, MBRP, 38r, DP F5, HPX, RR, DIY 6637, 05 OEM Harley front, 08 OEM rear & mirrors, 20" Moto Metal, 35" Nitto's
Current - '11 6.7 FX4 Larait, Ready Lift 3.5" Leveling Kit, '13 Larait Wheels
Dasaliac03 is offline
post #3 of 8 Old 01-31-2011, 04:02 PM Thread Starter
You got any idea of why mine wont do that like I said even in Low she poops out
post #4 of 8 Old 01-31-2011, 05:16 PM
rolsmojave3's Avatar
Mine will take off in 2nd with no issues, My gas Ranger can take off in 1st and 2nd with no throttle most of the time. Brake(s) dragging?
1997 Ford F-350 4x4 SRW regular cab manual trans.
-4.10s, 315/75r16...getting a frame off restoration. Go fast stuff
1996 Ford F-350 4x4 SRW CCLB manual trans. CALI spec
-ATS intercooler, WW2 w/ 1.0 housing/EPBV delete, Comp 910s, SD Efuel, 3.55s, 315/75r16
2002 Ranger FX4 with manual transfer case and Alcoa's
rolsmojave3 is offline
post #5 of 8 Old 01-31-2011, 05:48 PM
mo powerstroker's Avatar
my 03 takes off in L and first no problem with no throttle
mo powerstroker is offline
post #6 of 8 Old 01-31-2011, 05:51 PM
Mine is a 6.0 never had a 7.3 with a manual so maybe they are different
post #7 of 8 Old 01-31-2011, 05:52 PM
justinlogue5_0's Avatar
Find a small down hill run and see if it will run down hill by itself. If not you could have brake,bearing etc... issue. However if it was the brakes I would think you would have smelled it by now
It gets me there, What more could I ask for?
justinlogue5_0 is offline
post #8 of 8 Old 01-31-2011, 06:09 PM Thread Starter
I got a small hill on the end of my road I'll give that a try if not I'll start takin stuff apart lol
