pressure plate - Ford Powerstroke Diesel Forum
post #1 of 2 Old 12-08-2010, 05:23 AM Thread Starter
PowerstrokinIt F250's Avatar
pressure plate
my dual mass flywheel is going out and i got a used single mass with a good clutch a new pilot bearing and throwout bearing. the only thing is that the pressure plate on it is no good. i cant seem to find a pressure plate anywhere with out buying the whole clutch assembly. does anyone know if maybe the pressure plate from my dual mass will work? the single mass i have is a 13 inch flywheel. i dont want to take my dual mass out without having the single mass ready to put in. if it will not work does anyone know where i can get just the pressure plate? thanks.
[IMG]http://i59.tinypic.com/33l06ll.jpg
1995 f350 7.3 4x4 auto 4door long bed 160,000 miles BONE STOCK for now. Cleanest truck in PA
1998 Mitsubishi Eclipse GSX 9.9@ 152mph
2003 Honda Civic daily driver
PowerstrokinIt F250 is offline
post #2 of 2 Old 12-08-2010, 05:46 AM
ryandamo's Avatar
the dual mass flywheel will not work, not sure where you can find one, try contacting a manufaturer and seeing if they will seperate it
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
