97 PSD bogs while at idle - Ford Powerstroke Diesel Forum
Old 12-01-2010, 10:14 AM
I have a 97 F350 PSD with 328K miles. Recently, while at idle, or even coming up to a stop sign, it will try and bog down. After a few seconds, it will go back to a normal, smooth idle. I replaced the fuel filter but it didn't help. Could this be a sign of a injector pump going bad?
Old 12-01-2010, 11:16 AM
It could be your exhaust back pressure valve or EBPV. It is used to make the engine work harder when it is cold to make it warm up faster. If you notice it only does this on cold days that is probably it. Do a search on here to find all about it.
Old 12-01-2010, 04:38 PM
mine did that.it was the torque converter locking up when it wasnt supposed to.removed trans and found converter welding itself to the pump
Old 12-01-2010, 05:25 PM
PSD's don't have a mech. injection pump. What is you oil level?
Old 12-02-2010, 05:01 AM
id unpug the ebpv, but id start thing TQ converter pr ICP/IPR. and x2 no IP for these trucks.
