p0108 Baro Map code even with new sensors - Ford Powerstroke Diesel Forum
Old 11-30-2010, 06:32 PM
I started out chasing some transmission issues and found that I had a P0108 Baro Map Sendor high voltage code. When I clear the code the the transmission line pressure issues are corrected. The problem I am having now is I have tried three different MAP sensors but I still get the same p0108 code. I have even tried a different PCM and still get the same code. Any help would be appreciated.
Old 11-30-2010, 06:39 PM
One more thing. When I unplug the Map Sensor I get the same code of p0108.
Old 12-01-2010, 03:06 AM
I just found that there is a Barometric Pressure sensor inside the cab that is causing my code. I had no idea this even exsisted. I will have to get one and see if this clears up my transmission problems. When I unplug it I get P0107 code. Thanks and Here's to hoping it corrects my problem. Just for any guys with the same problem in the future I found that the part numbers are F8UZ12A644AA or Motocraft DY-846. Thanks again.
Old 12-01-2010, 09:12 AM
The new sensor fixed all the issues.
Old 12-01-2010, 10:11 AM
Good deal,I too never heard of such a sensor,paticularly in the cab.Thanks for sharing
