Window problems.
Here's the low down. Crew cab truck, all windows work from the main control on the drivers door and other doors. Problem is when the power feed is hooked up to run the windows from any other window door switch in the truck, it is blowing the circuit breaker in the fuse panel. I disconnected the power feed and drivers door controls all windows no problem. But now I can't run any other window with the power feed disconnected. Anyone have this problem?
mine was doing that with the driver door side. I ended up replacing the fuse panel. I also had to replace the switch.
I have a extra fuse panel, & have seen the switch on ebay. Mine apparently was cuz everything got wet, but I was sick of replacing not so cheap relays. good luck to you, hit up m-chan he is great at this stuff |
One of my rear doors windows would go down but not up,I took the door panel off and found a wire had rubbed bare and was grounding,don't know why it worked going down but not up,crazy.
First off, what are we working on? That piece of information is very important. Second of all, let's clarify what the exact issue is. From reading the original post, NONE of the power windows work with their respective switches, but will operate with the master (driver's) control, is that correct? And replacing the master control with a new unit (assuming it's a new one from Ford) did not fix the issue, correct? What exactly do you mean by the power feed?
It's a 1997 crew. Replaced the switch with oem Ford. By power feed I mean the one at the bottom of the switch that feeds power to the other window switches. When that is hooked up it has a huge power draw and trips the circuit breaker in the fuse panel. I disconnected the power feed to the othe windows and they all work from the drivers door switch but not from the other windows since the power feed is not hooked up. Fixes the circuit breaker from tripping and until I figure out the problem.
Problem solved, thanks for the help!
