Get 3.08s in front axle? - Ford Powerstroke Diesel Forum
Old 11-30-2010, 06:53 AM
94 7.3 250 4WD 5 speed. The rear axle is a 3.08 ratio that came out of something else. The front seems to be the factory 4.11. I don't pull anything with the truck and don't plan on it except maybe a small camper. I do some off roading but nothing serious. I like the 3.08 for highway use. I don't want to go 4.11 on the rear to match the front. Question; can I get a 3.08 for the front axle?
Old 11-30-2010, 06:55 AM
Almostdunfukinwidit
Check Randy's Ring and pinion to see if its offered.
Dont use your 4wd until you match the ratios
