Allison Transmission Swap - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-29-2010, 02:04 PM Thread Starter
bigman8u4lunch's Avatar
Garage
Exclamation Allison Transmission Swap
Im building a list to aid in swapping an allison into an OBS (or any 7.3) so far
Allison T1000/2000 (4X4) depending on application
Adapter Plate
Stand Alone Controller
Drive Shafts Modified?
mounts
Almost everything new, is here Allison 1000 Performance Transmission from PATC, Allison 1000 Performance Parts
you can find used parts which would be cheaper on craigslist or ebay and if anyone wants to modify the list go ahead this is something im starting to see what people do with it. :twocents
1st: 1996 7.3L F350 CC LB, Exhaust Housing, DP, Cold Air, Transcommand, TS 6 bank chip, On Board Air,
Built E4od, Efuel, TC lock-up, EBPV exhaust brake
2nd: 1999 7.3L F350 CC LB DRW, TS6 chip, Flat Bed
bigman8u4lunch is offline
post #2 of 12 Old 11-29-2010, 04:21 PM
ryandamo's Avatar
youd be better off swapping in a built e4od allisons arent all there cracked out to be in stock form
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #3 of 12 Old 11-29-2010, 04:29 PM
maybe use a 545. a little more heavy duty, but you probably need to pound the trans tunnel a little; ok alot.
rorybellows is offline
post #4 of 12 Old 11-29-2010, 05:27 PM Thread Starter
Garage
the T1000 6 speed is a dual over drive so when im just cruising on the long haul rpm will be lower and my fuel economy will go up. Im looking for a stock tranmission that wouldnt have an issue withstanding 700+ ft/lbs from the engine. if built right can also handle a hell of alot more HP. my link above has everything with a few supplemented components, it will work
post #5 of 12 Old 11-30-2010, 05:30 AM
kylev90's Avatar
Quoted: 4 Post(s)
sounds like a sweet project. A little off topic but how do you like that transcommand?
1997 CC SB. Stage 1s, 17*hpop, S&B CAI. 4" straight pipe, TW tunes, zf5 swap
kylev90 is offline
post #6 of 12 Old 11-30-2010, 05:36 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Dont waste your time. Build your E40d and be done with it.
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #7 of 12 Old 11-30-2010, 11:51 AM Thread Starter
Garage
Its not that bad, but when im on and for a bit and let off just before the shift point i go to the chiropractor for realignment, its smooth cruising otherwise
post #8 of 12 Old 11-30-2010, 12:00 PM
Quoted: 5 Post(s)
less time, less money, less headache by building a stocker up, BTS, suncoast, etc. Allisons are not the greatest thing, not nearly as tough as they used to be
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #9 of 12 Old 11-30-2010, 12:08 PM Thread Starter
Garage
Its not an issue of time for me, its what i would like to do. The equipment needed has been made for the swap. it will be simple for me. im just waiting for my tranny to go out but in the mean time im getting the parts together.
post #10 of 12 Old 11-30-2010, 06:53 PM Thread Starter
Garage
Is there anyone who has attemted this or is doing something similar
