just bought a 95 stroker
i just bought a 95 powerstroke and it wont switch to the front tank i changed the switch on the dash and no work i figure now its the switch valve can i change the lines on the valve to run on the front tank to see how much is in there
maybe. it might be easier to pull the fuel sender and look. your fuel sender or something else could be messed up, but its more likely the pollack valve.
im not sure how all that is wired up but i would think you could swap, should work just fine. |
