CB= Too Much Draw For Batteries??? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 11-29-2010, 10:39 AM Thread Starter
RadarRider's Avatar
I just finished installing my Cobra 29 on my truck & now I've got some sort of a surge problem. I originally wired the CB directly to the driver's batt.(the CB itself, has an inline fuse). I started the truck up & let it run for awhile as I haven't driven it in about a month. Now, when I turned the radio on, nothing seemed to be wrong. But when I keyed the mic, the idle of the truck had dropped like the battery was draining. Just for shiggles, I took the (-) & hooked it up to the (-) on the pass batt & I get the same thing, maybe a hair better.
I hooked up my multimeter to see what I was getting for voltage. @ idle, the batts. bounce around between 13.6 & 13.58 with the radio on or off. When I keyed in the mic, it drops to about 13.4-13.44 & won't climb any higher until I release the mic. The batts. are relatively new Optima Yellow Tops & the CB itself is just a regular ham radio with no modifications.
I've had CBs hooked up to past gasser trucks with single batts & never had this problem. I don't get the alt. light & the dummy needle doesn't move when I key the mic. Is this plain-jane radio really drawing this much voltage, or is there something else I need to check? How about better suggestions for (+)/(-) hook-ups? Anyone else ever have this problem?
"HEAVY" 2001 F-250 XLT 4x4 EC SB:
TW 6pos chip, S&B CAI, Monster 4" exhaust w/ Power Elbow, Big Head WGA, Technicooler, ITP boost fooler, Gen 1 Wicked Wheel, Six-Gun Tuner, Optima Yellow Tops, AutoMeter(Boost, Trans, EGT), CCV mod, MTS TC, MTS valve body, Trans Tech performance rebuild kit, TransGo shift kit, Hornblasters 242 Shocker Train Horns.
RadarRider is offline
post #2 of 13 Old 11-29-2010, 10:42 AM
ridiculously_necessary's Avatar
even if your alt was dead it shouldnt do that imho. something isnt right. how many watts or amps is it pulling? thats weird.
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #3 of 13 Old 11-29-2010, 10:45 AM Thread Starter
RadarRider's Avatar
I'll have to pop out the CB to see what it's ratings are, but you're right; this shouldn't be happening. I've had another Cobra 29 hooked up to an old '87 Chevy C-10 directly to a 6yr old battery & never had this problem. You'd figure a Cobra 29 is a Cobra 29. There shouldn't be a whole helluva difference, right?
post #4 of 13 Old 11-29-2010, 12:36 PM Thread Starter
RadarRider's Avatar
Bump
post #5 of 13 Old 11-29-2010, 01:12 PM
Chop's Avatar
Have you tried connecting power source inside the cab?In my truck drivers side has a host of possible connections.Just a thought.What I remember about cb's they were 4 watt power max ,are you going over that?Possible ground problem?
1996 F250 PSD Crewcab,auto,D 60 swap,3" dp, DIY air 4X4 Centurion
Chop is offline
post #6 of 13 Old 11-29-2010, 01:25 PM
There is another issue....maybe some sort of interference from the output of the radio.
A Cobra 29 shouldn't pull enough juice to make any difference what so ever unless it has been HIGHLY modified.
What type of antenna are you using and how is the coax routed?
PsRumors is offline
post #7 of 13 Old 11-29-2010, 03:23 PM Thread Starter
RadarRider's Avatar
The radio's 100% unmodified right out of the box. The antenna's just a 3' metal whip with a magnet base I bought from a Pilot Travel Center. There's absolutely nothing special about this radio.
post #8 of 13 Old 11-29-2010, 03:33 PM
bull36575's Avatar
where is the antenna
bull36575 is offline
post #9 of 13 Old 11-30-2010, 11:52 AM Thread Starter
RadarRider's Avatar
It's mounted on the roof just above the 3rd brake light. The coax runs between the bed & cab, underneath the cab, up through the engine compartment, & through the hole in the firewall just below the master cylinder, past the steering column, & the CB itself is mounted underneath that little shelf next to the cup holder.
post #10 of 13 Old 11-30-2010, 12:04 PM
justinlogue5_0's Avatar
Do the truck lights dim or just the radio lights? I am thinking that you may have developed a cb issue inside. I have a highly modified cobra 29 with a wilson 4' intenna on the roof. I had to get the extra large power cord for the radio to help the radio get the power it needed but I ran them just to the body for a ground and then to the driver side hot post. I can key up and talk all night with no issues or drain on the truck. I would take your radio to a respectfull cb repair shop and let them check it out. They should only charge a couple dollars just to check it for ya. Good Luck!
A little bit of this and a little bit of that. I want a lot more of this and a lot more of that
It never ends!
justinlogue5_0 is offline
