Investment? - Ford Powerstroke Diesel Forum
post #1 of 11 Old 11-28-2010, 10:28 PM Thread Starter
Taskforce51's Avatar
Investment?
Would it be worth my time and money to buy a 97 F350 4x4 with a bad trans and 300,000 miles for $3000. What does it usually cost to rebuilt the engine and trans?
Taskforce51 is offline
post #2 of 11 Old 11-29-2010, 08:42 AM Thread Starter
Anyone? Anything?
post #3 of 11 Old 11-29-2010, 09:08 AM
Assuming you have the E40D, if you pay someone to rebuild your trans, I believe you're looking at about $3000. Don't know about the motor -- does it have to be rebuilt?
KBB says the truck is worth $5280 in fair condition, private party value.
Brian
'96 F250 SC, 7.3, 4x4, E40D, and it's red... and white.
retmotor is offline
post #4 of 11 Old 11-29-2010, 09:34 AM
ridiculously_necessary's Avatar
id take it! is it a crew cab?
espicially i the motor check out. personally id do a compression test, thats 70% of the story on the motor. a tranny rebuild i have seen $1000 to $3000. depends onwho and what you want. the 350 has a D60 and that alone on worth up to $1k.
if the motor check out id try and talk them down but probably take it either way.
-Matt
Late 99 (2/99) Black F250, CC LB 4x4 Lariat 214k. All Stock for the moment...
1995 PSD, ext cab, one wheel wonder
, 297k miles, 30k on wvo. totaled 5/8/11 RIP This truck is for sale as a parts truck (Jason is about to receive forged rods, and drop kick his PMR's)
DB high torque starter
DIY 6637
Marinco Mod
DIY Electric fuel w/ wvo conversion
"A clean house is a sign of a mis-lead life."
ridiculously_necessary is offline
post #5 of 11 Old 11-29-2010, 09:49 AM
Adam-Arc's Avatar
If the motor is healthy go for it. The shop that did my trans told me a rebuild should last 150k. The 7.3 is good for at least 500k. 300k has a lot of life left in it.
Post some more details- mods, issues, body
97 F350 CC 4x4 Auto Welding Rig
Steamfitters Local 475, Newark, NJ
IDM mod/Homemade CCV/10k/6637/3"dp/4" exhaust/no cat/muffler
Adam-Arc is offline
post #6 of 11 Old 11-29-2010, 10:10 AM Thread Starter
not to sure about the engine i just want to be sure the truck is going to last and no it is an ext cab..
post #7 of 11 Old 11-29-2010, 10:37 AM
get the engine checked. definitly do a compression test since you are concerned about it lasting. stay on top of maintenance and they will last at long long time. get what maintenance info you can from the PO. in general if the oil was cared for, and the intake probaly maintained it should be fine. psd's use oil for injection and old oil isnt good for the hpop, ipr or injectors. again, if your compression checks out i would feel good about it. even if i foudn a few wear and tear parts that had to be replaced soon.
-Matt
DIY 6637
Marinco Mod
post #8 of 11 Old 11-29-2010, 10:39 AM
Adam-Arc's Avatar
Dig deeper. If it was maintained or needs minor maintenance it is worth it.
X-Mas is around the corner. 3000 asking means 2200 cash on the hood to me.
Put the bills on the hood in front of his wife and see if you can pick them up before she does.
Adam-Arc is offline
post #9 of 11 Old 11-29-2010, 10:43 AM
-Matt
DIY 6637
Marinco Mod
post #10 of 11 Old 11-29-2010, 10:51 AM
Adam-Arc's Avatar
Learned this from my old man.
I beat up many a poor soul with it.
The problem now is my wife knows the deal and uses it against me. triple
And boy howdy is she quick!!
Adam-Arc is offline
