No axle blocks?
While fighting the low-hanging fuel tank in an attempt to change out the brown fluid in the rear diff
, I noticed that my 95 dosn't have any blocks. The axle is sitting directly on the spring perches. Were blocks standard, or was there an option for a block delete?
A 250 would have a 2" block, a 350 would have a 4" block.
Are the springs stock? probably not. A previous owner must have replaced the springs, and used ones with more arch to do away with the block. |
My 2wd F350 obs had no blocks in the rear.
I see in your sig that you truck has airbags in the rear. The block was likely removed to keep the rear from being too high with the bags under it.
The springs are stock. Truck sits level but annoyingly low. Overloads were removed and bags added.
Now if I only had a real axle in the front I could raise both. WTH was Ford thinking when they decided to use a TTB 50.
I wonder if the front springs sagged, and they removed the rear blocks in a backwoods effort to level it.
