C P S problem??? - Ford Powerstroke Diesel Forum
Old 11-22-2010, 04:26 AM
C P S problem???
On two occasions my truck would miss out of the blue,as if it cut off,the last time it ran a little rough and then returned to normal.I did not get cel either.My question is this the CPS?
Old 11-22-2010, 08:21 AM
drives a ranger
Send a message via AIM to kanuck15
It doesnt seem like the CPS, when you say cut off is it like you just turned the key off? or does it stumble a bit?
Old 11-22-2010, 09:15 AM
Yes, just as if you turned the key off and on as quick possible.A small hiccup and begins to purr as usual.Fresh oil and fuel filters,as I said it has happened twice and I thought it at first maybe the ignition switch could have been have way in the on and off position,but I can't duplicate it by hand so i ruled that out.The last time it did stumble a bit after the intial miss,but cleared with in seconds
Old 11-22-2010, 09:57 AM
drives a ranger
Seems like electrical to me, id be cheking connections
Old 11-22-2010, 10:32 AM
scuffs *****
Send a message via AIM to Tyler
Mine will do that if I goose it, lift and goose it again on old oil. I just change the oil and it goes away
Old 11-23-2010, 09:58 AM
I agree it must be an electrical but it it is alarming when it happens and always restarts without any problems.I did get a chance to clean and inspect engine and all wiring connections ,I noticed I have a black CPS and not the gray one I have read about on this forum,could it be my problem?I mean this truck with 97 k runs like a top,smooth idle,good response thru out.But any way I will replace the CPS with newer version and see what happens.Thanks for the help!!
