HPOP reservoir - Ford Powerstroke Diesel Forum
Old 11-21-2010, 04:13 PM
HPOP reservoir
I have a opportunity to get some parts from a 96-97 7.3. Can the HPOP reservoir be swapped easily? Thinking of picking up the reservoir so I can easily swap the HPOP without worrying about drain back issues.
Old 11-22-2010, 07:29 AM
what year you swapping into? iirc the only difference is a gasket and standpipe...
tell me more about this drainabck issue, i think im having the problem myself and not sure where it woudl occure. is in actually a deal in the resivour? or is it that valve attached to the hpop?
Old 11-22-2010, 03:18 PM
Swapping into my 95. Don't have a drain back issue yet, but I would if I put a newer style HPOP in. IIRC there is something called an edge filter in the HPOP or the IPR that is different between the 94-95 and 96+ motors. I know Joey at TE can swap the HPOP housings, but was thinking it might be easier not having to do that.
Old 11-22-2010, 04:32 PM
well I will send you whatever you need john just let me know what all you want
Old 11-23-2010, 04:53 AM
yes, the 95 has a screen of sorts on the IPR. but i have been told its not necessary.
