still no start......help! - Ford Powerstroke Diesel Forum
Old 11-20-2010, 10:31 PM
so a few weeks ago my truck randomly died and still hasnt started. i was getting ipr valve codes and oil codes and i replaced the hpop nwith a 17* and a new ipr valve. i erased the codes before i started the truck with the new parts in. turn it over and still didnt start, no smoke or anything. open the fuel bowl drain after cranking and it has alot of pressure behind it. so i find a idm out of a super duty but im not sure if it worked or not, but still no start. im getting no codes now just p1000 what do i do next? no scanner yet. soon i hope. any info will help
Old 11-21-2010, 05:27 PM
how much have you cranked on it? did the hpop reservoir drain to empty. my icp went bad, which talks to the ipr. all the oil drained out of the reservoir. when i put a new icp on it took a lot of cranking and i mean a lot before it started. just wandering out loud about yours. my reservoir filled up quick, but still took a lot of cranking
Old 11-21-2010, 08:03 PM
Do u have the wait to start light. My fuel heater wire broke shorted out and blew a fuse. The same fuse that sends power to the pcm might be something to check.
Old 11-25-2010, 12:28 PM
everything works in the truck. the wts light and all. turns over fine. i did notice when i took the hpop res off everything was still full. oil was full and everything. cranked it for a long time. icp is probably something i need cause mine had alot of soot on it. gunna scan it today. wish me luck
happy turkey day
