D60 Question - Ford Powerstroke Diesel Forum
post #1 of 15 Old 11-18-2010, 06:24 PM Thread Starter
D60 Question
If I swap out the d50 for the d60 will it get rid of that need for constant steering input to maintain anything vaguely resembling a straight line?
Brian
'96 F250 SC, 7.3, 4x4, E40D, and it's red... and white.
retmotor is offline
post #2 of 15 Old 11-18-2010, 07:55 PM
Feedback Score: 3 reviews
You replace the steering stabli?
96F350KID is offline
post #3 of 15 Old 11-18-2010, 08:29 PM Thread Starter
Re: steering stabilizer. No. It's relatively new. It's always done this since my dad bought it over ten years ago. Also my 95 2WD does the exact same thing if not a little worse. I took that truck to a front-end guy (who is so anal he physically modified an a-arm on my old car just to get another degree and a half of camber). He gave the front end a green light and said that's just the way those TTB front ends are. My 99 F250 didn't wander.
Brian
retmotor is offline
post #4 of 15 Old 11-18-2010, 08:50 PM
My D60 swap wanders all over the place but the truck has a burned out steering box... Hows the play in your steering box?
1995 F250 Single Cab.
D60 Swap and Super Duty springs.
315/75/16 Tires.
Custom Light Bar for night missions.
BrianH is offline
post #5 of 15 Old 11-18-2010, 08:56 PM
Rangers Lead The Way!
kanuck15's Avatar
Quoted: 10 Post(s)
idk my one dana 50 truck drives like an arrow, where as my 250 with a dana 60 swap is straight-ish, but my 350 wanders all around
Trucks and parts............
kanuck15 is offline
post #6 of 15 Old 11-18-2010, 08:57 PM
Denver_Diesel's Avatar
I just completed (yesterday) my d60 swap, and yes, in my case it solved that problem completely. My TTB was spent, needed new everything including tie rods and ball joints and pivot bushings - and yes my truck wandered down the highway like a drunk sailor. Now steering and tracking is excellent, but FYI I put on a completely rebuilt D60 kingpin and all new tie rods, shocks and tires. twasn't cheap.
F-250 PSD
VW Touareg V-10 TDI
MB 300D
Denver_Diesel is offline
post #7 of 15 Old 11-18-2010, 09:00 PM
kanuck15's Avatar
Quoted: 10 Post(s)
haha yeah those arent cheap to redo. It all depends on your axle/steering/tires. my 250 i swapped wandered bad but with spent ball joints and little tires it was crap. now with brand new ball joints, a 60, and 37s shes straight and narrow
kanuck15 is offline
post #8 of 15 Old 11-19-2010, 02:14 AM Thread Starter
Well, I have almost zero play at the steering wheel so that tells me it's OK although I did have someone once tell me that doesn't mean the steering box isn't worn, but that makes no sense to me.
So it's not necessarily a d50 thing then.
Yes, that's the wander I'm talking about, although yours sounds a bit worse than mine. So I may be looking at worn components, but from what I've read repairing the d50 is a bit like polishing a turd; at least where swapping in a 60 is an option. I did just replace the BFG Commercial A/Ts with Michelin LTX A/T2s and that helped a tiny bit. Shocks are still good.
...my 250 i swapped wandered bad but with spent ball joints and little tires it was crap. now with brand new ball joints, a 60, and 37s shes straight and narrow
So it sounds like a d60 rebuilt or in good condition will fix the problem unless the steering box is worn.
Alright then, I'm going to recheck the front end for anything that may be worn and move the d60 swap from the "one day" budget, to the "one day soon" budget. Thanks, all.
Brian
retmotor is offline
post #9 of 15 Old 11-19-2010, 06:59 AM
kanuck15's Avatar
Quoted: 10 Post(s)
first off regardless of steering a D60 swap is a good idea. that center u joint is a ticking time bomb and once she goes it usually takes the axle with it.
secondly I do not know how but there is a way to tighten up our steering boxes. I will do more research on it and see what I can come up with
kanuck15 is offline
post #10 of 15 Old 11-19-2010, 07:47 AM
Not sure about these boxes but. On top of the box there is a Hex bolt with nut on it. Loosen the nut and tighten the hex bolt. Not to much or you'll screw up the box. I can.t remember exactly what it tighten but if you tighten it to much it kills the box in no time. If I remember correctly its a bearing or collar it tightens. But like I said not sure if these boxes have that.
97 XLT EX Cab long box 4X4
DIY 6637 intake
Shimmed FPR
4" AFE exhuast system
Autometer Gauges
Tony wildman Chip.
More to come as finances allow!
JP667 is offline
